May 19, 2024, 12:11:57 PM *
Author Topic: 3 Wire.... PS Choke?  (Read 6254 times)
Carl WA1KPD
« on: November 28, 2014, 10:59:51 PM »
I am cleaning up the junk boxes and have come across several items that look like smaller 2" X 2.5" tube era power supply chokes. But they have 3 wires, all coming out of one side. Leads on one are yellow, red and blue.
Any ideas what they are?
/KPD
« Reply #1 on: November 29, 2014, 01:47:49 AM »
Sounds like a TV vertical output transformer.
« Reply #2 on: November 29, 2014, 02:37:04 AM »
I agree,  vertical output xfmrs, never been able to find a use or them.
« Reply #3 on: November 29, 2014, 08:09:00 AM »
What's the impedance of the most turned windings? Used for an audio choke in a regen? Or if impedance is too low used as a choke ignoring the tap?
« Reply #4 on: November 29, 2014, 02:14:59 PM »
I have used VOTs as supply filters ... worked ok at 100mA or so
WZ1M
« Reply #5 on: November 30, 2014, 02:52:14 AM »
Altec/Peerless used a taped choke in some of there units. I just rewound one.
TRS
Gary
« Reply #6 on: November 30, 2014, 04:07:16 AM »
UTC made three terminal chokes.  They are the PA series chokes.  Main portion of the choke is the second and third terminal.  The first terminal had a 1mfd cap to ground.  Some sort of resonating the choke.
« Reply #7 on: November 30, 2014, 06:03:00 PM »
What about using them as a mod transformer in a single ended class A arrangement with one lead acting as an auto transformer connected to the PA?  Maybe a five watt rig for ten meters?
« Reply #8 on: November 30, 2014, 09:03:51 PM »
The ratio is such that the 'secondary' would be too high for a speaker and too low for much else, although use is possible for a 'line' or where a large voltage signal is wanted but not as much as on the plate. Look for 45-200 Ohms when hooked to a 6V6 or something. Deflection yokes vary wildly so it is hard to say what Z ratio unless you measure.
It might be used as a modder, if you have a step-up with the low Z winding on top. Question is how much DC can pass before the audio-like characteristics go bad?
Use one for an audio choke to supply DC to the class C stage and one just the same for the modulator, and another as the mod transformer with capacitive coupling. Looks like a nightmare waiting.
The things have good HV insulation since they handle a vertical retrace pulse that can be 500-1200V, and work at 60Hz, and even lower, if one has a vertical hold control on the TV set. They are not so good at high audio frequencies, kind of purpose made.
Whatever it is, the thing is a well made autotransformer and you have to use your imagination to find a use. small B+ choke is not a bad use.
« Reply #9 on: November 30, 2014, 09:06:39 PM »
BTW color code:
yellow: vertical Yoke hot side
Blue: plate
red B+
yoke return depends on which end the low z winding is on. usually returns to B+ red.
« Reply #10 on: November 30, 2014, 10:50:12 PM »
/KPD
Carl,  if you see any part numbers on the xfmr I should be able to cross reference the xfmr to a Stancor or Thordarson xfmr.  From there I can determine the ratios and impedances.
Carl WA1KPD
« Reply #11 on: December 01, 2014, 09:53:59 AM »
Thank you- I will pull them. As I recall there was nothing on them
Page created in 0.038 seconds with 18 queries.
