May 19, 2024, 05:54:16 PM *
Author Topic: Dipole Question  (Read 5932 times)
KE5YTV
« on: November 16, 2014, 12:23:11 AM »
I'm putting up a inverted V dipole at my home. The center will be at 40' sloping down to 8' at the ends. My problem is that one leg will pass over a concrete parking area. My question is, how will the concrete affect the antenna performance?  Huh
Mike
Mike
KE5YTV  Dallas, TX
KX5JT
John-O-Phonic
« Reply #1 on: November 16, 2014, 04:09:53 AM »
Concrete is simply an insulating (non-conductive) material sitting on top of ground, I think it will be very minimal.  Just make sure it's high enough that vehicles can't take it down.
AMI#1684
« Reply #2 on: November 16, 2014, 12:04:58 PM »
Concrete is not an insulator.
Try grabbing a 120 vac leg while standing barefoot on that wonderful insulator.
Hopefully you'll still be alive to report back on your findings.
Search UFER  grounding for more info.
Bad piece if information here.
KC2ZFA
« Reply #3 on: November 16, 2014, 12:58:07 PM »
detailed info here: http://www.iotpe.com/IJTPE/IJTPE-2013/IJTPE-Issue16-Vol5-No3-Sep2013/14-IJTPE-Issue16-Vol5-No3-Sep2013-pp96-101.pdf
« Reply #4 on: November 16, 2014, 02:51:05 PM »
Unless the area covered by the concrete is exceptionally large, the effect will be just about zero. In other words, don't worry about it.
aa5wg
« Reply #5 on: November 16, 2014, 08:17:06 PM »
I agree with Steve.  The effective result will be minimal.  There could be steel re rod inside the concrete.
However, from experience this had a zilch effect on my antennas.
Chuck
« Reply #6 on: November 16, 2014, 10:17:02 PM »
Mike
I might only be a problem if you park a tall truck in the parking area.
KX5JT
John-O-Phonic
« Reply #7 on: November 17, 2014, 05:33:21 AM »
I stand corrected then... it's not an insulator... hmmm... well... at least the idea of it not being very significant to a dipole above it holds.
AMI#1684
KE5YTV
« Reply #8 on: November 17, 2014, 11:27:20 AM »
Thanks guys! I was afraid that the antenna performance was really going to be compromised. So now, it's full speed ahead.
Mike
Mike
KE5YTV  Dallas, TX
« Reply #9 on: November 17, 2014, 03:01:51 PM »
What bands are you trying to use?
Inverted Vees are very good antennas for those who cannot have a true flat top dipole.
Are you planning to use a remote tuner? or are you going to find a sweet spot?
KE5YTV
« Reply #10 on: November 17, 2014, 05:28:22 PM »
Hi Fred,
80-15 meters with a tuner.
Mike
Mike
KE5YTV  Dallas, TX
Page created in 0.037 seconds with 18 queries.
