March 15, 2026, 11:36:53 PM *
Author Topic: Johnson 500 Power Switch/w/Key  (Read 2622 times)
WD7F
« on: August 26, 2014, 04:40:32 PM »
Found a surplus source for a switch and key that works just fine on the 500.  Here's the link: http://www.surplussales.com/Switches/SWAssort-1.html Arrow Hart Division of Crouse Hinds part number 81715.  Comes with one key, bezel and nut.  Cheep!
WD7F
« Reply #1 on: August 26, 2014, 04:44:40 PM »
Just in case you're interested, you can pay $69.90 for the same thing here:  http://www.wellgainelectronics.com/arrowhandhkeylockswitch3a250vac2pos-1.aspx
k7iou
Johnson Viking Five Hundred
« Reply #2 on: August 28, 2014, 10:26:37 AM »
The replacement switch is made by the original manufacturer. The new key is slightly thinner than the original and the head of the key is slightly different shape but works fine business in the original switch. So if you lost your key get this switch. The replacement single pole switch is rated 6A 125V, 3A 250V. The original double pole had both poles soldered together for the same rating.
See attached picture of original key and replacement switch in bag.
de k7iou
Page created in 0.028 seconds with 18 queries.
