May 19, 2024, 05:51:21 AM *
Author Topic: VIKING ONE AND A HALF  (Read 3337 times)
Detroit47
« on: February 25, 2014, 06:45:00 PM »
My Viking 11 seems to be a little different than most. There is no clamper tube or any of the associated circuit and no holes punched for the socket or the VR. I also noticed that there was a negative feedback circuit in it the same as a Viking 1. I was wondering if anyone else has ran across this? Also how can i tell if this one was factory assembled?
John N8QPC
« Reply #1 on: February 25, 2014, 08:25:59 PM »
"Also how can i tell if this one was factory assembled?"
Usually, if the tube sockets are riveted, its a factory unit. Less production time.
Hambone wiring (solder blobs, loads of pine tar and burnt insulation) indicates home made work. I'd show you from my work, but I can't find my camera.
« Reply #2 on: February 25, 2014, 08:29:13 PM »
Wa1HLR has the patent on the V 11/2
N3GTE
« Reply #3 on: March 03, 2014, 05:10:27 PM »
I have a Viking II set up like that also. Methinks it's an early version as it is a bit like the Viking I .
Also have a Viking I with an 829B in the final. It needs a clamp tube. Not enough grid drive and the 829 goes poof!
Terry
Detroit47
« Reply #4 on: March 04, 2014, 09:55:03 AM »
I kinda figured that it was from a transition period. If it was a kit there must be a different assembly manual for it than the usual one. Unless it was factory assembled.
John N8QPC
W8EJO
« Reply #5 on: March 04, 2014, 10:52:11 AM »
John N8QPC
Mine has a decal on the chassis that indicates it was factory built.
Also, I've heard that all of the CDC models, which mine is, were factory built.
Terry, W8EJO
« Reply #6 on: March 04, 2014, 01:44:42 PM »
John N8QPC
They had to be to comply with the FCDA regulations at the time.
Detroit47
« Reply #7 on: March 04, 2014, 02:33:03 PM »
John N8QPC
Now I got to ask where is the decal at on the radio? Also is there screws or rivets on the tube sockets.
John
