May 16, 2024, 11:26:29 AM *
Author Topic: Is anyone running these tubes?  (Read 7118 times)
« on: December 20, 2013, 12:24:27 AM »
Specifically the vintage Taylor T-20 or TZ-20 triodes.
Just curious.
W8ACR
254W
« Reply #1 on: December 21, 2013, 10:25:32 PM »
Not here Dennis, but if you send me two of each, I'll build a T-20 X TZ-20 rig. Cool
73 es Merry Christmas
Ron
« Reply #2 on: December 22, 2013, 10:19:54 AM »
VE3NCC, Craig was running TZ-40's mod by '20's I think.
Last I heard. Think he's upgraded his call too but it's been awhile.
« Reply #3 on: December 22, 2013, 10:22:30 AM »
Wow! That's a good memory Rick. I was thinking that I had talked to someone in the past using one or both of those tubes. I think it may have been Craig.
« Reply #4 on: December 22, 2013, 01:11:25 PM »
Since the T-20 is essentially a type 10 on steroids, and will do enuf RF to be worth the work, I was thinking of putting together a Jerry Gross-esque transmitter down the road.
I have the tubes stashed, and most of the vintage parts on hand.
Not 1929 early, but done up in mid '30's style.
Ron S. doesn't get to build one before me nya nya nya. Tongue
« Reply #5 on: December 22, 2013, 05:23:10 PM »
Steve et. al., I'll look in the log and see if I recorded more of Craig's lash up. Sure at least about the TZ-40's.
Later:
Found one mention, 14Aug. '94.  3880kHz, 180 watts AM from my Shoebox 813 rig (811a's)
Craig running Pair of 813's mod. By pair of TZ-40's.  All run with common 1600 Vdc supply.
A note also about "Judy, no code." Fwiw.
Yeah, I think a PP pair of '20's link coupled mod by a pair would make a neat  ol' buzzardly rig.
Don't forget the round meters with arrow pointers.  Grin
Carl WA1KPD
« Reply #6 on: December 22, 2013, 05:33:38 PM »
I have a nice HB rig that runs a pair of T-20s. Puts out about 120 watts
« Reply #7 on: December 22, 2013, 07:01:35 PM »
I spy an RK-34 doing the mod duty there.
Do you know who built this rig?
kb3ouk
The Voice of Fulton County
« Reply #8 on: December 22, 2013, 07:02:57 PM »
Wonder how many times the builder or anyone else who used that transmitter bumped into that feed-thru insulator on the front panel while tuning it up? And that's not an 815, or at least not any 815 that I've ever seen, the glass on that tube is shaped a lot like an 807.
« Reply #9 on: December 22, 2013, 07:19:11 PM »
Maybe one of those Hytron dual tubes?
« Reply #10 on: December 22, 2013, 08:08:48 PM »
Prolly an RK-34, I corrected my previous post.
Carl WA1KPD
« Reply #11 on: December 22, 2013, 09:43:29 PM »
Don, That is a RK-60 rectifier. CW only
It was was W1PLW.
Here is the schematic he drew
Carl WA1KPD
« Reply #12 on: December 22, 2013, 09:45:24 PM »
I put it there. If you look closely it is a dummy. The builder had the SO239 on the front, something I cannot stand the look of   Cool
kb3ouk
« Reply #13 on: December 22, 2013, 11:03:28 PM »
Oh ok, I saw what looks like a set of wires off the side that have an SO-239 soldered to them and that the insulator was disconnected, but I figured you did that so that there wasn't any exposed RF on the front panel.
« Reply #14 on: December 23, 2013, 09:09:56 AM »
Fascinating construction. Upside down IF can used for a tube shield and  neat sideways mounting of crystals, etc.  Looks like plugging those crystals in and out has bent the Osc. Plate coil more than once. Maybe turn the assembly around with a trap door facing out the side for easier crystal changing?  Nibbling a square cut into the side rail a ways won't hurt.
Like to hear that baby on the air.
There's a front panel 1/4 in. Drive, variable link coil w/ plug in jack on eBay now, but add'l shaft and knob would upset the present front panel symmetry.
Really nice, period front panel. -Black wrinkle supreme..  And the insulated antenna out could be hooked up. Hey, what's a few hundred RF volts anyway?  Grin
Could you please take a focused shot to ease reading of labels?
