March 19, 2026, 04:04:27 AM *
Author Topic: Supressor modulation question  (Read 3953 times)
« on: December 01, 2013, 06:29:02 PM »
Suppose you have a pair of pentodes in push-pull as supressor modulated finals.
Does one feed the supressors out-of-phase audio or in-phase Huh
« Reply #1 on: December 01, 2013, 06:31:20 PM »
DG
Is this a trick question??
« Reply #2 on: December 01, 2013, 07:08:16 PM »
I haven't ever thought about suppressor modulation; but the modulation of a pair of tubes in push-pull should be applied in the same phase to both tubes... regardless of the type of modulation.
« Reply #3 on: December 01, 2013, 07:09:13 PM »
Nope..I just can't find a definitive answer.
For single or parallel, it is simple. But PP?
BTW, I do believe that is the shortest answer Stu ever posted...
« Reply #4 on: December 01, 2013, 08:24:42 PM »
Stu provided the simple answer.  It is no different than plate modulating a push/pull final in that the modulation is applied in the same phase to both tubes.
« Reply #5 on: December 01, 2013, 08:37:21 PM »
OK boys, I'll hook it up as a single source of supressor voltage.
Many thanks for the quick replies! Cheesy
