July 13, 2026, 11:41:28 AM *
Author Topic: Hallicrafters HT-40  (Read 51708 times)
« on: July 22, 2013, 06:43:11 PM »
Updated: 9/2021 With Text, Schematics, and Theory of Operation:
* HT-40 Preferred Upgrades.pdf (529.04 KB - downloaded 1395 times.)
KK4RF
« Reply #1 on: October 09, 2013, 05:28:55 PM »
Phil,
     Thanks for the message on the HT-40. I'm running mine stock and for the most part have been getting fairly good audio reports. Your mods do look pretty interesting, however, and I may look into them again at a later date.
     Working on another ScreenModulated/controlled Carrier rig, the KnightKit T150-A. It does not get very good audio reports, however. I plan to read up on as many mods for that radio as possible.I'd like it to sound as good as the HT-40. Thanks again, Phil.---Marty, KK4RF---
« Reply #2 on: October 22, 2013, 12:14:12 PM »
I am glad to hear your audio is acceptable, but I would bet if you looked at the modulation with a scope, it probably has no more than 75% modulation unless it has been modified.
And having the Red Led modulation indicator is a lot of fun.  Cheesy
If you are working on the T-150, check out these mods here as well:
http://amfone.net/Amforum/index.php?topic=34680.0
I have another update coming with actual operating parameters noted during operation.
n4joy
« Reply #3 on: February 02, 2014, 10:11:43 AM »
This is a good write-up.  I firmly believe the HT-40 is perhaps one of the best carrier controlled transmitters for AM beginners.  I use mine on 10 meters and always receive good audio reports with its stock configuration.
« Reply #4 on: February 02, 2014, 05:06:47 PM »
Thanks.
I also get good audio reports as well.
With a few component changes and additions the audio and modulation can be improved.
The R-C feedback circuit from the Modulator cathode back to the speech amp really helps to reduce distortion.
And the 6DQ5 final is both low cost ($7.50 to $10.00) each and pretty darn rugged.
