June 26, 2024, 03:33:03 AM *
Author Topic: Viking Ranger Help  (Read 7424 times)
Burt
« on: May 16, 2013, 05:48:51 AM »
The PTT relay is open, therefore in order to operate phone I have to put a key in the down position and seperately actuate a relay to do antenna changeover. How can I get it back to before the PTT relay was added as I have no use for PTT anyway. I just want 110v  appear on the rear output pins on both phone and CW, not just CW.
It is a good thing I had a problem as I found out the 110v input cord was frayed. The fused plug was a pain to get back together.
« Reply #1 on: May 16, 2013, 08:24:17 AM »
Burt, you might wish to replace the relay. The mode switch is a nightmare to change and the wear from T/R is plenty. The relay saves future heartache.
Burt
« Reply #2 on: May 16, 2013, 03:41:42 PM »
The relay is no longer made, subs?
Plus I have no desire to use PTT and would wire it permenently on.
I won't use the Ranger that much and just want to make it work on phone without throwing three switches
« Reply #3 on: May 16, 2013, 09:57:03 PM »
Part number or closeup pix may help someone figure out what is there.
wa3dsp
« Reply #4 on: May 17, 2013, 01:37:21 AM »
OK dumb question - if you are just going to wire it on then why not just short the normally open contacts on the relay and cut the wires to the coil.
The relay that is in there is the wrong way to go even if you want PTT. There are many ways to replace it but I used a 12V relay and derived 12V from a 12VCT transformer 1/2 across the 6.3 VAC line.
See - http://www.crompton.com/hamradio/JohnsonRanger/RangerRestoration.html
Burt
« Reply #5 on: May 17, 2013, 11:59:26 AM »
Good responses. I do not know why I did not think of just shorting the contacts and using the function switch. It works the way I want when I do this, it switches the 110v for the relay the way I want. I have no desire to use PTT.
Burt
« Reply #6 on: May 18, 2013, 02:44:17 PM »
Burt
Add the letter n between the r and t of your name. That's what the function switch will land up being after a while.
« Reply #7 on: May 18, 2013, 08:44:55 PM »
Dave C. should write for Dave L.   Grin
Burt
« Reply #8 on: May 19, 2013, 06:07:07 AM »
Burt
With the voltage coming out of the mike connector at the current setup, over 200v, I will be burnt if there is any leakage.
I won't be using the Ranger that much. It is easier to replace the switch than me
« Reply #9 on: May 19, 2013, 06:59:32 PM »
That would be one way to get rid of me. Sri wrong network.
« Reply #10 on: May 19, 2013, 07:00:37 PM »
Burt
It's current limited.
Burt
« Reply #11 on: May 19, 2013, 07:29:28 PM »
Burt
When I touched it I threw a screw driver across the room. Missed my monitor by an inch.
« Reply #12 on: May 19, 2013, 08:18:06 PM »
200V on a PTT line. WTF?
« Reply #13 on: May 19, 2013, 08:22:56 PM »
Burt
You need practice.
Burt
« Reply #14 on: May 20, 2013, 06:13:37 AM »
Actually it was 300v with no load, it is a 115v relay, when loaded it is 115v, but the coil resistance is lower than my finger.
VE3AJM
« Reply #15 on: May 20, 2013, 07:42:05 AM »
If you don't want to use any PTT, just remove the PTT circuit and components return the transmitter to original, and take your chances with using the function switch??
Or, find a replacement low voltage multipole/throw relay and drop the coil voltage accordingly, and your worries about high voltage on the PTT line will be taken care of. They're not hard to find.
Al VE3AJM
