May 13, 2024, 11:16:04 AM *
Author Topic: Have you built a frequency counter kit?  (Read 2978 times)
K4RT
« on: January 16, 2013, 03:04:21 PM »
I’m wondering if anyone has built a frequency counter kit and with what results  I see kits for counters up to 50 MHz listed on ebay and other web sites. Looks like they use a broadband amp IC with no attenuation feature. I’m curious if this kind of counter is reliable in calibrating a VFO in a typical HF tube transmitter covering 160 to 10 meters, etc.? Also wondering if the broadband amp picks up internal and external noise that might detract from the counter’s use.
« Reply #1 on: January 16, 2013, 03:12:22 PM »
Almost All Digital Electronics.  Can't say enough good things about his counter.   Although, for solid state xtal oscillators, it DOES need a preamp.
However, for most tube style, a capacitive input probe is FB.
W4AMV
« Reply #2 on: January 16, 2013, 05:25:57 PM »
I have a homebrew counter used in my HB receiver. The counter uses 5 volt CMOS. My only recommendation is be sure to not use a clock reference in the counter which is a harmonic or sub harmonic of your Rx IF.  Sad
« Reply #3 on: January 16, 2013, 07:27:23 PM »
do you feel like building a kit?
if not, then just pick up a working counter on epay, or else a DVM with a counter and/or a stand alone
feq counter module, ur done.  maybe you need a preamp, but that's a simple thing to add on... kinda doubt
that you would.
Btw, if you have a good quality scope that has a "vertical out" on it, that will upscale whatever signal you
put on the scope's input -effectively a preamp.
                             _-_-
« Reply #4 on: January 17, 2013, 08:53:20 AM »
Brad,
Pay particular attention to the quality of the time base used within the counter.  Either a TCXO or oven is a good way to go.  Some cheap counters use cheap time bases and it requires you to re-zero the XTAL before you take any serious measurements.  With test gear, I like accuracy and a cheap counter won't give you good long term accuracy.  My recommendation is to pick another kind of kit to built and get a good HP or comparable counter off of one of the internet sites.
Joe, W3GMS
K4RT
« Reply #5 on: January 23, 2013, 02:33:13 PM »
Guys -
Thank you for the advice. I will probably buy a used counter, but will need to shop around and compare features, range, etc.
Brad
« Reply #6 on: January 23, 2013, 06:02:32 PM »
Yes, built a Heathkit IM2410 back in the 80's. Good little counter. Good for 225Mhz but I hardly use it these days.  I used it when I was a novice a using an HW-101.
