May 18, 2024, 10:53:45 AM *
Author Topic: Viking 500 J110 - Broken chassis plug  (Read 2543 times)
kc2we
« on: January 10, 2013, 08:39:56 PM »
The J110 center post on the (RF) chassis mounted 9 PIN female is broken on the "500";  just placed the unit on the work bench. Got it that way from the estate sale. I want to replace it (don't want to guess about pin allignment any time the inter-connecting cable is removed). The only available chassis plugs I can find on the web are black bakelite and the original was mica filled (yellow). Any reason why the black won't work here? It's only carrying control voltages - no RF. I'm tempted to replace it with an MS style 9 pin military connector set (about the same footprint) and be done so it can't be broken again. Any ideas for a source for the 9 pin "noval" plug though? I guess can be installed with a standard tube socket spring washer and the run-of-the-mill mounting plate if I find one. Suggestions welcomed. Smiley
Seth Taylor
« Reply #1 on: January 10, 2013, 09:29:52 PM »
This is a very common issue with this type of connector.  The antique radio supply stores sell a little piece that slides over the pins of the existing connector and has a new locator pin but I have never seen them for anything other than 8 pin plugs.
Several years ago I acquired a couple of Pierson KP-81 receivers and both had broken locator pins on the chassis mount 11 pin connector.  I really did not relish the idea of replacing these since the original wiring is dense in that area.  Instead I used a Dremel tool to cleanly smooth off the remains of the original pin and then used the same tool with a cutoff disc to liberate a pin from a defunct tube.  I carefully aligned the replacement pin and attached it with high strength epoxy and that worked fine.  I have since used this method to repair several connectors.
N8ETQ
Mort
« Reply #2 on: January 10, 2013, 10:00:53 PM »
Yo'
   I run into this quite a bit. My low cost, low hassel
solution is to paint a line with red nail polish across
the Properly oriented Plug right up on to the chassis.
2  or more coats may be required as it's "Pigment
 Deficient". But fairly resilient. Not like your pulling
them too often anyway.
GL
/Dan
WD8KDG
« Reply #3 on: January 10, 2013, 10:10:41 PM »
Try http://www.leedsradio.com
they seem to have some of the old stuff.
Craig,
« Reply #4 on: January 10, 2013, 10:12:14 PM »
http://store.triodestore.com/9pinampl86.html
Leeds Radio also lists them: http://leedsradio.com/parts-connectors.html
« Reply #5 on: January 11, 2013, 02:03:18 PM »
tried mouser, digikey and allied radio .... not much to find but may not be tickling the search engines just right .... cootchie coo
Page created in 0.038 seconds with 18 queries.
