The J110 center post on the (RF) chassis mounted 9 PIN female is broken on the "500"; just placed the unit on the work bench. Got it that way from the estate sale. I want to replace it (don't want to guess about pin allignment any time the inter-connecting cable is removed). The only available chassis plugs I can find on the web are black bakelite and the original was mica filled (yellow). Any reason why the black won't work here? It's only carrying control voltages - no RF. I'm tempted to replace it with an MS style 9 pin military connector set (about the same footprint) and be done so it can't be broken again. Any ideas for a source for the 9 pin "noval" plug though? I guess can be installed with a standard tube socket spring washer and the run-of-the-mill mounting plate if I find one. Suggestions welcomed.
