May 07, 2024, 05:05:49 PM *
Author Topic: Ameco"s Duo-Grid AM Modulation  (Read 3941 times)
WB6LSI
« on: December 05, 2012, 10:28:25 PM »
How does Ameco's Duo-Grid Modulation work? It was use in the TX-62 VHF and TX-86 HF CW & Am transmitter. Thanks.
Henry
« Reply #1 on: December 05, 2012, 11:20:07 PM »
It looks like a combination of metered control- and screen-grid modulation of the final amp to me.
kb3ouk
The Voice of Fulton County
« Reply #2 on: December 05, 2012, 11:26:11 PM »
Except for the TX-86. On the schematic I found, that transmitter appears to use pure screen modulation.
WB6LSI
« Reply #3 on: December 07, 2012, 05:44:17 PM »
Thank you for the replies. The operating instructions states: "The TX-86 uses the new, low distortion DUOGRID MODULATION. It is NOT clamp tube or controlled carrier modulation but a far superior system with quality that cannot be distinguished from push pull plate modulation, even with an oscilloscope." DUOGRID may just be what Ameco calls it. I checked the ARRL site but didn't find anything. I was thinking it was something like AM modulating a transistorized transmitter by modulation both the driver and the final.
Henry
K9PNP
« Reply #4 on: December 07, 2012, 07:58:30 PM »
Dug out my TX-62's manual.  Here is what it says in addition to Henry's quote from the TX-86 manual which is also in the TX-62 manual:
"The second tube, α 6GK6, is the modulator . It
is connected to the 7984 final screen as α Heising modulator.
Α proportion of the audio signal is also fed into
the control grid of the 7984 . With screen modulation
alone, distortioninc increases sharply above approximately
65% modulation. When the grid is also modulated, as in
the Ameco system, this distortion is reduced to α very
low value permitting clean, 100%, modulation with α very
simple circuit . When the transmitter is operated on CW
the modulator tube is reconnected as α clamp tube to
protect the final in case of loss of excitation. On phone,
the reduced screen voltage provides some protection for
the final."
73,  Mitch
WB6LSI
« Reply #5 on: December 08, 2012, 02:24:59 PM »
Thanks Mitch. I have a copy of the schematic of the TX-86, which isn't very easy to read, but it does appears that the grid is also being modulated.
Henry
