May 06, 2024, 04:42:33 PM *
Author Topic: 250 TL in a BC-610-I ???  (Read 3130 times)
N8ETQ
Mort
« on: March 16, 2012, 01:38:24 PM »
  Hi,
          Got a 610-I here for  checkout and intial "Flame Up".
Made by B&W say's the tag. Looks good and was allegedly
in use. Has 250 TL in the PA. Can you do that?  TIA
/Dan
« Reply #1 on: March 16, 2012, 02:20:56 PM »
Ther 250 TL and the 250 TH have different bias requirements.....The 250th was the standard final in the BC-610 if I remember correctly...
« Reply #2 on: March 16, 2012, 02:46:45 PM »
The low-mU "TL" will work OK, but carefully watch the plate current if drive is lost.
N8ETQ
Mort
« Reply #3 on: March 16, 2012, 09:19:11 PM »
  hey Dennis and Steve,
    Thanks, I figured it would work, the low MU thing explains the
nice new 807 IPA's in this thing!  it came with the VFO, Manly
device indeed.
/Dan
« Reply #4 on: March 16, 2012, 10:03:36 PM »
Looks as though you are set for RTTY now! Cheesy
« Reply #5 on: March 16, 2012, 11:50:24 PM »
You might need to change the grid leak resistor for the TL.  The grid drive with the new resistor will be lower and the bias will be higher.  The TL will need more protective bias voltage than the TH. Check the tube charts.  With the appropriate adjustments, the TL should work just as well as the TH.
