March 08, 2026, 03:32:58 AM *
Author Topic: UTC PA-307  (Read 4349 times)
Detroit47
« on: January 23, 2012, 07:05:06 PM »
I have an UTC PA-307 transformer and no information on it. I looked thru the bunker and came up with a zero. Does anybody have the spec's on it.
Thanks John N8QPC
KE6DF
« Reply #1 on: January 23, 2012, 07:18:48 PM »
Look up CG-307 -- it's same only slightly different shape.
3500 3000 2400 - 0 - 2400 3000 3500  at  300ma
I have a CG-308 which is the same only 500 ma.
Dave
Detroit47
« Reply #2 on: January 23, 2012, 08:03:25 PM »
It is ahuge transformer for only 300 mills. I'd say at least 70 lbs.
John N8QPC
« Reply #3 on: January 23, 2012, 08:14:35 PM »
These monsters are all potted as well IIRC incl. the -309, the 1A King!
Detroit47
« Reply #4 on: January 23, 2012, 08:21:02 PM »
So unless I am wrong if I set it up center tap full wave, With a choke input I'm looking at about 840 watts of power out of that thing.
3500 X .8 = 2800     2800 x .3= 840  Unless I have my head up my ____
John
KE6DF
« Reply #5 on: January 23, 2012, 09:11:55 PM »
John
That's sounds right. Probably a little higher voltage than 2800.
And it's a CCS transformer. So it will do that all day plus weekends rain or shine.
Those big CG/PA transformers are very conservatively rated and high quality.
« Reply #6 on: January 24, 2012, 01:32:40 AM »
As you probably already know, do not use a full wave bridge. It will ruin the xfmr.
Detroit47
« Reply #7 on: January 24, 2012, 04:11:19 AM »
All them old peices of iron were made for ct full wave with L input.
Thanks John
K3YA
« Reply #8 on: January 24, 2012, 10:04:51 AM »
I have a CG-306, a slightly lower voltage version, in my 4-1000 GG linear.  It's connected to a full wave bridge, capacitor input supply providing about 6 KV.  It's been running about 15 years now without problem, so the center tap must be pretty well insulated.
KE6DF
« Reply #9 on: January 24, 2012, 10:48:35 AM »
Is yours a CG306W?
The ones with the W suffix were designed to work in a bridge circuit.
There is a 1970 UTC catalog out there on the web that states this and show both part numbers.
Dave
