May 03, 2024, 02:31:15 AM *
Author Topic: how to use a filament transformer without center tap  (Read 12702 times)
W8ACR
254W
« on: January 22, 2012, 11:49:06 PM »
Hello all,
I have a very nice UTC filament transformer rated 5V@30A, I believe the part number is H20. This is a beautiful transformer that I would like to use in my next project. However, it has no center tap on the secondary. How would I use this transformer to power the filaments of, say, a pair of 250TH's? A simple hand drawn schematic would be nice.
Thanks, Ron W8ACR
« Reply #1 on: January 22, 2012, 11:57:56 PM »
250TH's filaments are 5V at 10.5 A. What's wrong with just putting the filaments in parallel?
« Reply #2 on: January 23, 2012, 12:11:44 AM »
Ron,
    I presume your looking for a way to use that transformer and be able to return the cathode current to ground without getting an imbalance, or 60 hz hum on the 250 TH cathode. Two options come to mind:
1.) Make a centertap from two resistors in series where each end is across the power transformer, and the junction of the two is the tube cathode return. These resistors need to be pretty small in ohms to not add a cathode bias, like two 10 ohm 2W resistors.
2.)  Use another transformer (much smaller) like a Radio Shack 12.6 VCT @ 1 A. Use the 12.6 volt winding just like the resistor. Here the DC resistance of the winding will be pretty low, so there should not be much added cathode bias like with the resistors.
W8ACR
254W
« Reply #3 on: January 23, 2012, 12:17:54 AM »
Hi Pete,
I thought there had to be a ground connection to complete the DC circuit. I understood this to be the purpose of the usual center tap. In other words, if one lifts the center tap the circuit is broken. The only other option that I could think of would be to ground one side of the filament transformer and likewise ground one of the tube filament connections.
Or - more likely -  is my assumption way off base?   Huh
Ron
W8ACR
254W
« Reply #4 on: January 23, 2012, 12:20:16 AM »
Yes Jim, that is what I was referring to. I understand your instructions OK. That sounds simple enough.
Thanks, Ron
Jeff W9GY
« Reply #5 on: January 23, 2012, 06:25:03 AM »
I've used a 12.6 V center-tapped small filament transformer wired in parallel across the main transformer.  Then use the CT of small filament transformer as a "phantom" center tap.  Works great.
Jeff  W9GY Calumet, Michigan
(Copper Country)
« Reply #6 on: January 23, 2012, 07:42:52 AM »
I am confused now.  I thought you needed CT for changing bias (if cathode driven) between cutoff and conduction.
Also, what is DC path to ground here about.  Isn't fil. current AC?
« Reply #7 on: January 23, 2012, 09:05:22 AM »
Rob,
       You still need a DC path to ground (or B-) for a complete circuit. No path to ground for the cathode, no current can flow through the tube. In a circuit using a directly heated cathode tube, it is usually done at the filament transfoma center tap to balance the AC offset and eliminate any hum problems from an AC powered filament.
Applying the biass to the filament center tap us usually done in a grounded-grid amplifier because it is the simplest way to do it.. If you want to apply the biass directly to the grid of a GG amp, you have to keep the grid at RF ground, while applying the biass, thus complicating things a slight bit and requiring a few more parts. Applying it to the filament CT is just the easiest and simplest way to do it.
K1ZJH
« Reply #8 on: January 23, 2012, 10:55:02 AM »
That is what I was going to suggest.
Pete
KE6DF
« Reply #9 on: January 23, 2012, 11:26:03 AM »
The filament transformer sounds great, but if  you are planning to use a cathode resistor anyway to provide protective bias to the tube, they you might as well use the two resistor method.
« Reply #10 on: January 23, 2012, 01:27:26 PM »
In that case, each resistor would need to be twice the nominal cathode resistance, since as far as plate/cathode current is concerned, the resistors are in parallel.
The two-resistor (or midtapped resistor) method has been in use since the advent of broadcast receivers using directly heated a.c. triodes dating back to the 1920s (226, 171 and 245 tubes).  The beauty of the circuit is that the resistors are effectively in parallel for cathode current, thus keeping voltage drop to a minimum, while they are in series across the low-voltage filament supply, thus pulling minimum current from the filament transformer.  The midtapped choke idea (or auxiliary midtapped transformer winding) offers the best of both worlds, although perhaps more expensive and takes up more space. Of course, the best idea of all is to have an accurately tapped main transformer winding, but you have to make use of what you have on hand.
« Reply #11 on: January 23, 2012, 03:46:44 PM »
If this a linear amplifer circuit in Grounded Grid configuration, the filament voltage is almost always AC while the cathode bias is DC provided by a zener brought in to the CT of the tranformer or the midpoint of the resistor circuit.
« Reply #12 on: January 23, 2012, 05:59:13 PM »
The bottom line, first, tell us what the project is??
« Reply #13 on: January 23, 2012, 06:06:17 PM »
Frank thanks for the explanation--I get it now.
« Reply #14 on: January 23, 2012, 08:04:33 PM »
  I have a Gonset GSB-201 linear amplifier with four G-G 572B tubes in parallel. This amp is good for 200W AM 80-15m, and a little less on 10m due to what appears to be high tank Q losses. Anyway I noticed from the beginning that on AM I had about 5% 60 Hz AM modulation that had a pure sine wave shape on the scope monitor. Looking at the schematic I notice that the filament transformer for the 572B's had no centertap. I was shocked saying WT_ at what appeared to be a glaring design short coming on this amplifier.
  Thinking hastily, I forgot about the center tapped transformer idea as mentioned above. I found a 50 ohm 25W rheostat in the junkbox, and went with that as the dual resistor method also mentioned above. So with this I get 25 ohms each side, or 12.5 ohms to ground for the cathode current. Since E=I*R, at 600ma * 12.5 ohms we get 7.5V drop (cathode bias). This certainly reduced peak power output of the amplifier, and reduced the gain a little. Then thinking about it, isn't this a form of negative feedback? The hum is gone, and the AMP is very linear now; almost as good as an 8877 based amplifier.
« Reply #15 on: January 23, 2012, 08:17:04 PM »
The series'd 10 Ohm resistors across the 3-500Z filaments make a nice CT and this works very well for the DC return.
« Reply #16 on: January 23, 2012, 08:24:47 PM »
The Gonstipated amp that I re-did for Derb had the same issue. It picked up a very noticable hum. I was a bit disdraught to see that the factory had grounded one side of the non center-tapped filament supply.
I did the 2 resistor fake center tap mod to it and all was fine afterwards. IIRC, I used a pair of 10 ohm 10w dogbones to do it.
« Reply #17 on: January 24, 2012, 08:41:02 PM »
The Clipperton L and similar 572B/811 amps from Dentron were the same. With more C the hum is way down on SSB/CW but may be noticable on AM.
« Reply #18 on: January 26, 2012, 07:42:04 PM »
Here are a couple of the techniques that folks have described in the thread. The caps would be required for for a conventional grounded filament amplifier.
W9BHI
« Reply #19 on: January 27, 2012, 01:52:02 PM »
Why couldn't you use 2 diodes?
Put the anodes of each diode to either side of the filament and tie the cathodes together and apply the bias there.
I have seen this done on an sb-200.
W9BHI
PA4WM
« Reply #20 on: January 27, 2012, 03:19:26 PM »
W9BHI
When reading this topic from top to bottom, I had the same idea....
I've never used two diodes, but have seen a few schematics using this configuration.
The cathodes on each end of the fillament transformer, and the anodes joining at B-
Martin, PA4WM
PA4WM / WM2J
« Reply #21 on: January 27, 2012, 03:46:51 PM »
Or zener diode. A great way to make bias for the tube. I tried it once on an 833A and the bias stayed steady at 90 volts no matter what the plate voltage was. It was a class B lineeeeeeer.
KE6DF
« Reply #22 on: January 27, 2012, 03:49:10 PM »
W9BHI
Martin, PA4WM
Wouldn't that result in ripple at 120Hz on the filament?
That is what you are trying to get away from with the two resistors.
Dave
« Reply #23 on: January 27, 2012, 07:10:40 PM »
Exactly, HUMMMMM - take an old linear amplifier like a Gonset GSB-201 with a 6V winding that had one side grounded. By lifting that side of the transformer and the four 811 fils off ground and making an artificial CT the, center can be properly grounded for nice HUM Free AM. Timmy turned me onto this idea.  Mike WU2D
W9BHI
« Reply #24 on: January 28, 2012, 10:54:12 AM »
Well just to satisfy my morbid curiosity I took my old SB-220 out of it's cabinet and flipped it over.
I disconnected the center tap of the filament transformer from the relay contacts.
I took two 3 amp 1000vpiv diodes and connected their anodes to the filament leads before the choke and connected the cathodes together and connected that to the relay contacts.
I fired it up and it loaded up just fine.
It had 4 milliamps less plate current than before because of the diode drop.
On air test showed NO hum in the signal.
W9BHI
