August 09, 2026, 03:31:29 PM *
Author Topic: QST article on tube life and filament voltage questioned  (Read 28278 times)
« on: September 28, 2011, 03:03:09 PM »
This is a critical safety and equipment operation notice.
Regretfully the October 2011 QST, on page 40, contains a fatally flawed filament voltage management article. Without question, the article gives life-threatening advice. The article specifically instructs readers to remove a protective cover and intentionally defeat a safety interlock by placing the reader's hand only inches from lethal voltages. The article further instructs readers to look away from their hand while high voltage is active...
Besides safety, the article's instructions will almost certainly lead to improper equipment operation or tube life problems. Nearly all instructions and information are wrong for any amplifier. Following the article, readers are more likely to degrade emission purity and tube life than improve either...
http://www.w8ji.com/qst_the_care_and_feeding_of_a_3-500zg_filament.htm
« Reply #1 on: September 28, 2011, 04:52:21 PM »
Hmm, I looked at that article and thought:
1.  At last, QST has something about equipment other than some solid state POS in a fish can powered by a 9 v. battery.
2.  The author had a valid point about high service v. ---> possible high fil. voltage and worth checking out.
3.  His method for lowering his worked I guess, but surely there is a better way than 12 feet of wire.
4.  I have a separate filament supply so I could use a variac.
5.  My service v. is 246 v.
etc. thoughts I can't recall now, but at no time did I think,
Oh, how dangerous, they'd better come up with an article on how to work on equipment without removing any covers.
I guess now that they have been spanked by the "authority" we can forget about ever seeing anything with vacuum tubes in QST ever again.  Maybe the same for tuners.   Someone might get an owie if he sticks his hand in one while transmitting.   It will be the author's fault for not telling the reader how to work on it with the cover on.
I don't recall reading anything about a hand inches away from B+ so I'll have to go back and read it again.
« Reply #2 on: September 28, 2011, 05:12:55 PM »
Anything that thins the herd of the appliance operator, and CB type operator is fine with me. Less QRM thanks to Old Sparky Grin
« Reply #3 on: September 28, 2011, 05:59:04 PM »
Nice to see Rauch following in Measures' footsteps with rebuttals.
« Reply #4 on: September 28, 2011, 06:29:03 PM »
What would they say about Ashtabula Bill's rigs and shack?  Bill's longevity suggests that exposed HV extends one's lifespan.
I did see some bogosity in that article. The 3-500 runs at nominal 5v, not 4.8v, and Tom is correct in that it's not filament burn-out that's the problem, but loss of emission over time due to destruction of the thoriated tungsten filament. I didn't care for  the copper wire resistor either. But I agree with the essence of the article: monitor the filament voltage at the tube pins and try to keep it as close to the nominal voltage as possible.
Maybe QST should stay with technical articles on building a QRP cw rig in a cat-food tin or an LED "On The Air" sign.
« Reply #5 on: September 28, 2011, 06:38:40 PM »
I guess the issue has to do with some AL80 layout specifics not made clear in the article (I don't own one) and the v. measuring instructions given by the author.   There were some general warnings about h.v. though.  Well, the Correspondence section will be interesting in about two months.
« Reply #6 on: September 28, 2011, 06:44:47 PM »
Not if the readers all get their tickets via Skype.  The content will have to be about who makes the smallest rubber duck antenna, or even non-radio articles.  They already have an "Eclectic Technology" column which seems to be about computers.  I'd rather read YL News and Views, but that seems to have mysteriously disappeared.
K5WLF
« Reply #7 on: September 28, 2011, 11:00:16 PM »
I'm sure as heck not the high power tube expert here. My hands-on experience with hollow state devices is pretty much limited to audio gear back in the good ol' days and some time spent on the Gates FM BC rig at college. But, I read voraciously and I'm getting ready to put a tube rig on the air shortly.
Between the QST article and the rebuttal by W8JI, there were a couple things that just didn't sit right with me. First off, I don't have a problem with working on equipment with the covers open and the power on. How else are you supposed to test it?? I guess I may have become somewhat inured to the excitement by working on my planetarium's star projector which has 40 KV to the anode of the CRT. Sure, the hair on the arms stands at attention, but it's way better than the time I got knocked out of my chair by 650 VDC on a Novice rig I bought half-finished back in '66. I've gotten smarter since then. I've got 36.5 KV inside the video projector in the dome too, and that hasn't killed me yet either. If you survive your early days, you learn to work safely around HV.
I've read a bunch of the Eimac material and never saw that 4.8 VDC was Vmax for 3-500ZG filaments. My mind was raising great big question flags, but I hadn't had time to go check the source material when Don posted the link here. As I remembered while reading, filament voltages are generally given as an integer voltage, plus or minus a tolerance. I'll definitely dig the Eimac spec sheets out of the PDF archive and see what the truth is.
The thing that really annoyed me the most was that WA2HMM's solution to the problem, as he perceived it, was a wad of THHN house wire stuffed in a corner of the amp. At least QST had the minimal decency to have an Editor's Note stating that a commercially available power resistor would have done the same job. No kidding, Sherlock? You really think so?
This article is just a continuation of QST's ongoing tendency to publish articles which do not embody what I consider good construction techniques. I've always believed that "if it works good, it should look good". Many of the articles in QST have photos that look like a bowl of multi-colored pasta was dumped in a dairy box or some other field expedient container. If I was unfamiliar with amateur radio, and my first exposure to the hobby was some of the construction projects in QST, it would be my last exposure to amateur radio. I am constitutionally incapable of doing work that looks that bad.
Obviously, W8JI and WA2HMM have differing views on the filament management of a 3-500ZG. I'm going to dig in the archives and come to my own conclusion. I'm motivated since a 3-500ZG may be coming to live at my house soon. One thing is for sure. I will certainly treat QST articles with a bit more skepticism in the future. I'm not sure who's right on this issue yet, but if there's that much area for doubt, I figure it behooves me to question all of QST's articles and do my own research.
Rob (K5UJ) is probably right. This may be the last article on hollow state devices that we ever see in QST. That'll make more room for drivel and swill about the digital modes and QRP rigs in Altoids tins and continuous QuaRMtests. Oh yeah, and interoperability and $65K Ecomm vans.
My cynicism runneth over.
ldb
K5WLF
Edit: I just remembered that Measures is the guy that's got the "main street at high noon" running feud with ARRL over amp design stuff. Why are they permitting him as a referenced expert in an article about amps? I'm puzzled.
W0BTU
« Reply #8 on: September 29, 2011, 12:15:21 AM »
When I read that, what jumped out at me was the article's first sentence or two. I lingered on that for the longest time, trying to figure out why that choice of words was allowed past the editors. (And I see I'm not the only one.)
The second thing that jumped off the page was that ridiculous wad of heavy wire. If he felt the need to reduce the filament voltage (which was a bad idea in the first place), a smaller gauge wire would have looked a heck of a lot neater, don't you think?
Since Tom was once almost killed by high voltage, I can understand why he feels the way he does. He's right! The HV on a low-current CRT PS is probably not going to kill you, but contact with a high-current amplifier power supply like that--even though the voltage is much lower--has a high likelihood of killing someone.
Anyway, nobody's perfect. Sounds like the editors of QST had a deadline and the tech editor was out that day. (Can you say, "teachable moment"?) Something tells me that kind of thing won't happen again in QST for awhile.
73 Mike
www.w0btu.com
« Reply #9 on: September 29, 2011, 08:43:28 AM »
Just FWIW, I have run the 4X1 in my 4X1 rig for the last 10+ years at between 6.75 and 7V. It is a coffee stained pull from a shaker table that I bought at the Fredneck fester for $25. I notice no noticable difference in performance, plate current, or outpoot if I vary the voltage from around 6.75-7.5V. (or filament brightness).
I figger that loafing it along at 6.75-7V just makes it a little easier on the thorium coated filament. So far it has worked, I have 10 years and bazillions of hours on it with no loss in outpoot. Just to prove to myself that I wasn't crazy, I put my brand new spare in just for testing purposes and found there to be no difference in performance, so I put the old one back in.
It sure looks purty with the plate glowing cherry red! ! !    Grin  Grin
« Reply #10 on: September 29, 2011, 09:32:52 AM »
Bill Orr would have had fun responding to that little QST piece Smiley
Life of filamentary cathode transmitting tubes is increased by managing voltage over the life of the tube but it isn't as simple as the QST author states.  Proper adjustment involves identifying the point where the emission begins to drop below the point necessary to support desired plate current and then voltage is increased to a bit beyond the point that restores required emission.  This voltage will need to be adjusted over the life of the tube-something best done with a Variac instead of cutting pliers for reducing the length of wire Smiley
Sustained operation with insufficient voltage will damage the tube.
I have worked on a lot of live equipment and at times that is by far the best way to make the required measurement or adjustment.  Some people should never go near live circuits but those are often the same people who could somehow damage a cast iron anvil with a foam rubber mallet.
I can understand articles that provide a point of view that may be controversial but printing incorrect specs that can be easily verified (4.8 V filament max) is a sign of carelessness.  I also question how many QST readers own a meter that is sufficiently accurate to make the called for measurement.  AC voltage is generally the lowest accuracy of any function of a typical meter and even if it met its specs when new (doubtful for the typical cheaper meter) it can easily drift over time.  Just because a DMM display is easily readable to .001 volt doesn't mean that is an accurate reading.
« Reply #11 on: September 29, 2011, 09:50:03 AM »
I suspect the 4.8V was due to poor proofreading and meant to be a minimum.
Rauch can often be ignored as about the only time he comments is in attack mode when something doesnt agree with HIS views which have often been proven wrong over the decades.
There are many more better qualified engineers out there.
« Reply #12 on: September 29, 2011, 10:11:23 AM »
a fight to the death between Measures and W8JI Friday night covered by the farce network
« Reply #13 on: September 29, 2011, 11:34:56 AM »
The number one bogus-osity of the whole thing is cheap amplifier design that uses one big transformer for both filament and plate voltages.  That's OK for BC receivers, tube type TVs and smaller transmitters like the DX-60 and Eico 720, but once you graduate to serious transmitting tubes (anything beyond tubes in the class of the 807 and 6146), you need a separate filament transformer.
The best way to maintain proper filament voltage is to use a transformer that actually puts out about 15% above nominal voltage at normal line voltage (and includes primary taps for 105, 115 and 125 volts), and use a rheostat in the primary to reduce the measured voltage at the tube socket to the desired filament voltage. That's how the BC-610 does it.  The advantages of this method over a variac are that the rheostat is smaller, cheaper and lighter in weight than a small variac, but more importantly, the series resistance in the primary circuit serves as a current limiter to absorb some of the surge when the rig is first turned on, and voltage is applied to the cold filament.
That's the same reason why, unless a series primary resistor is used, one should never use a vastly over-rated filament transformer.  If you use a 10-amp transformer to feed a 10-amp filament, the built-in voltage drop in the transformer will absorb some of the surge.  If you use a 50-amp transformer to excite a 10-amp filament, the tube suffers the full surge every time the filament is turned on, and this just might cause premature failure of the filament. Most of the damage is caused by the magnetic field during the surge; it physically twists,  compresses and contorts the filament structure.
I once noticed a similar phenomenon with the rf  choke I was using in the plate circuit of the transmitter. It was one of those multi-section pi-wound chokes, and the sections had all clustered together to close the gaps between sections. I replaced the choke, and within a few weeks noticed the same thing again. That's when it occurred to me what was going on.  The solution was to use a larger rf choke, and for added protection, I coated the whole thing with a heavy application of coil dope.
Back to the filament voltage problem, a solution I have thought about but never actually constructed, would be to use a variac coupled to a  heavy duty rotary switch as the main power switch in the transmitter. The variac would feed all the filament transformers and power supplies that turn on as soon as the filaments are lit.  It would work like the volume control in old tube type BC receivers, that used the "on/off volume control". You would turn off the transmitter by rotating the variac fully to the left to disengage the switch. This would  gradually reduce the voltage to everything before cutting power.  The rig would be turned back on by rotating the  control clockwise, first with the "click" as the switch engages, then, the variac is rotated to the right until the filament voltmeter reads full filament voltage.
During stand-by periods, the filament voltage could be reduced to about 80% normal, which according to the RCA book, greatly extends tube life. Letting the transmitter sit idle for hours at a time with full filament voltage is a waste of tube life.  The only drawback is making sure to remember to run the filaments back to full voltage before transmitting, since low filament voltage can do more damage to the thoriated-tungsten filament than does over-voltage.
« Reply #14 on: September 29, 2011, 12:44:08 PM »
A quick comment. I found out the hard way...
Years ago I used a pair of 6.3VAC filament 6146's as an RF plate modulated final. I didn't have the correct 6.3VAC filament transformer, so used a 12.6V AC xfmr on a Variac. The 6146 filaments were in series.
It worked FB until one day I decided to change these 6146 tubes around with some others in my junkbox.  While the tubes were still hot, I replaced one with a cold 6146. Within seconds the filament in the hot one opened up. I figgered it was a random bad tube. I then replaced the hot, bad one with a new cold one. Two cold tubes. The tubes worked fine.  Then I repeated this and replaced one hot one with a cold one and the hot filament opened up.  I did this a THIRD time with voltage meters reading the fil pins and was shocked to see a third tube filament pop. I was YELLAFIED!
What was happening?  I soon realized that with the tube fils in series, the hot one hogged all the voltage drop until the cold one warmed up. Thus the hot one had 11V++ volts on it and popped during the initial current surge. A cold filament is a lower resistance until it warms up.
This problem does not happen when using fils in parallel.   Some linears run series fils, so be careful when swapping tubes. Best to let them cool down first and/or use some kind of series current limiting system for warmup. Or use a Variac and bring them up slowly every time.
In addition, many times two fils are not matched well and there will usually be unequal fil voltage drop across the tubes. Series fils is not really the best idea man has ever thought of... Wink
« Reply #15 on: September 29, 2011, 12:52:16 PM »
When I got my box of 4CX3000As I measured the heater resistance at 5 volts operating because I didn't have a spec for the tube. I figured it was at least 5 volts, turned out to be a 9 volt tube.
The new tubes had a lower resistance than the old brown fin tubes.
« Reply #16 on: September 29, 2011, 12:54:56 PM »
You definately said a mouthful there! ! !  In all of the years that I have been fixing radios, I have found/had only a very few filament failures in transformer powered parallel filament radios. The series string radios (like All American 5s) and older series string TVs, this was a very common occurence!
« Reply #17 on: September 29, 2011, 01:13:54 PM »
Yeah, in working on AA5s, I read somewhere on the web to never put a cold tube in a hot radio or a hot tube in a cold radio because of this.  If you have a metered variac and use it to turn on an AA5 rx you can see the inrush on the current meter.  It is surprisingly large and the meter isn't fast enough to really get it.
« Reply #18 on: September 29, 2011, 01:23:20 PM »
<snip>
Tom - very interesting!  Never make that connection (pun).  That make a good case for me to go in and rewire all my fils in the Bendix TA12 for either 12 volt operation and use 1625s in place of the 807s or replace the 12SK7 tubes with the 6 volt equivalent 6SK7s and wire the fils in parallel.  Right now the fils take a 28 volt source to power up. Some creative combination of series connections are made in the filamenet chain.
Would the other alternative be to just make a practice of going off to a coffee break before powering up a xmtr after replacing one in a series wired filament chain? Just thinking out loud.
Al
Jim/WA2MER
« Reply #19 on: September 29, 2011, 01:35:27 PM »
If I ever get to meet W8JI, I'll have to ask him who pissed in his Wheaties!
Here's all the reader needs to come away from the article and this thread with:
1. Don't exceed or otherwise materially stray from manufacturer's component ratings if you want acceptable trade-off between component life and performance.
2. The QST article author could/should have been more careful with his interpretation and presentation of technical data.
3. The article author should have relied solely on, and clearly referenced, manufacturer published data only.  You don't cite what Eimac supposedly says, then reference an article by a third party...particularly one as controversial as AG6K.
4. The author's implementation of his solution to filament over-voltage is an example of a "ham-hack."  Other posts in this thread have covered this issue quite well.
W2BVM
"Anything worth doing is worth doing to excess."
K6JEK
RF in the shack
« Reply #20 on: September 29, 2011, 01:48:22 PM »
W2BVM
Jim, where'd you get that tie?  I like it.
Jim/WA2MER
« Reply #21 on: September 29, 2011, 01:59:06 PM »
[/quote]
From my son, the one who drew my portrait some years ago.  It doesn't bear any resemblance to me, but I just love the picture!
Bill, KD0HG
304-TH - Workin' it
« Reply #22 on: September 29, 2011, 03:47:39 PM »
Yes, filaments are managed in broadcast transmitters. But just because broadcasters do this, doesn't mean that hams operating their tubes intermittently would also benefit by doing the same thing.
No, I didn't read the QST piece. I don't get QST.
With a new or rebuilt tube, Eimac has always recommended running it at 100% rated voltage for a week or two to 'season' the jug. Then, while carefully watching peak modulation, running at full power and modulation, you can reduce filament voltage just to the point where you see positive mod peaks being impaired. Then turn it back up a hair. But you have to check this from time to time, it's not static. Also, in some cases, power line regulation becomes an issue.
But doing this is bloody silly in ham service, which is *not* 24x7. No ham runs their jugs at 100% power for 8,700 hours a year in transmit mode.
A broadcaster might get 10%-20% longer usable life out of a transmitter tube with proper filament management, but I firmly don't believe this to be the case for tubes run in typical ICAS.
The tube manufacturers all specify normal voltage limits for filament operation. That's where they should be run and not be screwed around with...Unless one enjoys a worthless activity.
Bill
« Reply #23 on: September 29, 2011, 04:03:56 PM »
Well stated Homie!!!
Which is essentually what Tom says at the conclusion.
In reality, despite the article's seemingly dramatic claims, amateurs will find virtually no tube life change from doing a great deal of work and having a great deal of anxiety, and doing nothing at all. This is because the vastly predominant tube failures in amateur radio use are tube shorts, with other failures related to repeated hot and cold cycling, and tube manufacturing defects. Emission failures from filament-hour depletion, while a worry in broadcast service, are virtually unheard of in amateur radio. However, operating a tube with improperly implemented reduced filament voltage, as advocated in the article, will make it more likely the emissions from the filament will decrease over time, due to poisoning of the emissive material.
I'm no real fan of Tom's, but the jest of his response is mostly right on. His delivery and people skills could use some work!
« Reply #24 on: September 29, 2011, 08:41:17 PM »
The Kenwood hybrids all use series connected 6146's and I havent heard of the hot-cold problem but most usually swap in pairs I guess. Ive rewired the TS-830 used to test amps for the 12V industrial versions since they are far cheaper.
The KW TL-922 amp and a few other brands run their big jugs in series also. I never did understand the reasoning since trying to get an equal didtribution at high current is damn near impossible.
Many amps are running filaments at overvoltage and even 5% high which is in "spec" WILL shorten emission life. Ive been careful to run all mine at around 3% low and longevity has been the result.
