March 03, 2026, 09:52:04 PM *
Author Topic: Care and Feeding of HV Electrolytic Capacitors  (Read 25922 times)
« on: July 29, 2011, 05:55:13 PM »
In an effort to finally fix up a 1939-era broadcast receiver for a friend, I finally put it on the bench after it had been collecting dust for over a decade, following the e-mail that she was coming up from Dallas in a couple of months and wanted to pick up her radio while she was here. I was able to repair the power transformer (rotted insulation on the wire leads where they exited the transformer case) and wooden knobs (replace the missing metal insert cores that fasten the knobs to the shaft). Next, I found that the electrolytic filter caps are totally shot - one open and the other a dead short, while others are still untested.
So I dug into my junk box and pulled out a handful of 20 mfd 450 volt electrolytics.  Some never used, others salvaged from equipment. Using my Heathkit capacitor checker (one of my more worthwhile dumpster pulls, made usable with the "illegal" Heathkit manual someone scanned and forwarded to me via internet). I found that every capacitor I checked needed "re-forming".  The Heath does that well, by applying a variable voltage up to 600v to the  capacitor through enough current limiting resistance to limit the leakage current to a maximum of a few milliamps. The voltage is slowly ramped up until the capacitor either refuses to re-form, or else eventually takes the full rated working voltage with low leakage current while displaying close to the rated capacitance. Then the capacitor is left overnight to "cook" at full rated working voltage, and is ready for service the next day.
Since every capacitor that I pulled from my box of electrolytics and checked needed re-forming, I have decided that perhaps electrolytics in storage periodically need voltage applied to them for several hours to maintain them in good condition.  HV electrolytics are like vacuum tubes, difficult to find brand new these days, and when you find them, very expensive, plus the new ones are of dubious quality (for example, the exact replacement can that I bought for one of my 75A4s for nearly $50, lasted less than a year before one section went open-circuit on me).
Once the capacitor is fully re-formed, you need to supply only enough current to maintain full rated working voltage, which can be achieved using a variable voltage power supply and current limiting resistor - or even use the capacitor checker itself.
Once this restoration project is out of the way, I think I'll go through my entire collection of electrolytics, throw out all the bad ones that refuse to re-form, run the good ones through the re-forming procedure, and periodically "re-charge" them in banks according to working voltage. I'll rig up a jig to hold all my 450 volt ones, 350v, 600v, etc., all wired in parallel, and after each capacitor is individually re-formed, apply voltage to the whole bank and let them cook periodically to maintain them in good condition. Since each capacitor pulls only a few milliamps maximum, a small power supply should be sufficient to cook a batch of a dozen or two at a time.
In order to keep a supply of working HV electrolytics on hand so that they don't self-destruct while sitting on the shelf, this would seem like good regular routine maintenance.
« Reply #1 on: July 29, 2011, 08:09:54 PM »
This has been discussed ad nauseum on serious restoration forums and the learned conclusion is that reforming a used electrolytic just leads one down the path of false security. It may self destruct in a day, month or year(s) when least expected and often with spectacular results.
First time forming an old but unused electrolytic is often successful if less than roughly 30 years old as long as its not showing physical leakage out the vent. However I never take that chance with my own or customer electronics that Ive been working on for close to 50 years. For certain items I restuff the electrolytics and paper caps with new modern parts.
If that person is truly a friend and you have a few months to fix the radio I suggest you dig under the mattress for enough moldy dollar bills and purchase some name brand caps from Mouser, etc. I would stay far away from the hamfest and basement sellers offering no name Chinese dreck at bargain prices.
Since Ive never spent $50 on any electrolytic for my 75A4 or any other item Ive no answer for your problem other than to tell the person you got it from.
Detroit47
« Reply #2 on: July 29, 2011, 08:37:33 PM »
I personally don't fool around with old caps period. I buy them by the hundred so I get a decent price and charge retail for them. That’s all I need is a return for some old trash. If that happens I make no money and waste my time. Even if it is my own stuff I go new. Now I don’t have any problem with some old oil filled caps. I’m talking about 5kv and up no TV stuff. I think the new caps are way superior to the old stuff period but you have to buy quality. You get what you pay for. When I do repairs I find 90% of the time it is a power supply problem, and this usually has something to do with a cap.
73 N8QPC
« Reply #3 on: July 29, 2011, 09:58:14 PM »
Don,
        Reforming "aincient" caps is a total waste of time and reliability, period! ! !
If they broke down once, they are going to do it again. Modern 450v caps are still pretty cheap. I have "modern" caps that are 20+ years old and have NEVER had a problem with them. How would you feel if your friend picked up their radio and a few months later it went up in smoke because of a failed reformed cap!
Some of the replacement canned multi section caps are a bit pricey, but single axial or radial lead 450v caps are still just a few bucks. Absolutely not worth the risk of using old crappy reformed caps.
Like Carl said, this has been discussed ad nausium here, on other forms, and I have personally doscussed it many times at the Mid Atlantic Antique Radio Club meetings.
I tend to look at the ones who preach the merits of using reformed caps as either lazy or cheap asses! ! ! !
If you have modern caps, just keep them and use them as needed. If you have old
(60s on back) caps, toss them in the trash before you end up catching a dose of
"disposaphobia"
« Reply #4 on: July 29, 2011, 11:16:22 PM »
The Mouser website lists single-section 20 mfd/450v electrolytics at anywhere from $25.15 each to $38.36 each. I don't think the whole radio is worth much more than that.  It has a beautiful cabinet (a nice  piece of furniture) but the radio itself IMO is a piece of crap. If I could find new replacement capacitors at a reasonable price ($10 ea. or so - I am open to suggestions) I would use them.
The replacement can I bought for the 75A-4 came from Antique Electronic Supply in AZ. I don't recall the name of the vendor, but they claimed they had bought out a well reputed old company (Cornell-Doublier, Sangamo or one of the other old capacitor manufacturers) and continued to use the original tools and manufacturing process to turn out identical capacitors "superior" to the original ones. The new can was rated at higher voltage than the original, but was otherwise physically identical and a drop-in replacement. But after less than a year, a severe hum developed and I found the dead section.  I simply bridged a replacement out of my junk box (without even re-forming it) across the bad section, and it has worked perfectly for several years now.
I do plan to add a fuse to the primary circuit of the transformer just in case a cap shorts out. If the radio is playing well when she comes to pick it up, I figure I have done my part, since this is a freebie and I'm not charging her anything for more hours of work than I wish to think about. I'll let her know about the capacitors, and maybe she can find someone in the Dallas area who could replace them if they crap out.
After this experience, even if one purchased a bunch of brand new capacitors just to have some spares on hand, I would still recommend applying the working voltage periodically to electrolytics in storage to keep them from going bad on the shelf.
« Reply #5 on: July 29, 2011, 11:23:13 PM »
I re caped  my r 390A with caps from here.
http://www.justradios.com/capacitors.html
I was amassed at how small modern electrolytic  caps are.
This company screwed up my order by sending me wrong caps. He replace them without charge and didn't want the other caps back.
N8ETQ
Mort
« Reply #6 on: July 29, 2011, 11:44:00 PM »
Hey Don,
   Seems like a lot of hassel for a few bucks worth of caps.  "Let them Go"
new ones are only a 2 to 4 dollar investment and are far superior to that
old crap. Since you have a couple mos. of lead time you should just call
Tom at Hayseed.  You can get regular value/voltage Jobs mailed right
away, If it's a can it may take a couple weeks but the reliability is what
your looking for.
   The new ones will fit inside the cardboard tubes of the old ones if you
need that.  A 47uf 450v axial job is $3.50 and it wont pull 2 or 3 ma. Maybe
20 or 30 uA but I have not measured it.  I do know if you charge one up and
toss it on the bench for a week or so it will still "get ya". (Don't ask)
Here is my quote from Tom:
Sales at Hayseed Hamfest Co. wrote:
Oh, okay, I see, Dan.  You just need some regular axial electrolytics. That, I can fix you up with.  With today's tolerances, the standard value would be a 47 uF and I have some of those rated at 450V that are about 1-1/2" long and 3/4" dia.  Four (4) of them would run $15.60 + $3.50 shipping (unless you wanted to wait until your other caps were ready).
/Dan
« Reply #7 on: July 29, 2011, 11:58:09 PM »
Terry, the outfit in Ontario seems more like what I was looking for.
Dan, can you post some contact info for Tom at Hayseed Hamfest Co. ?
If it were my own radio, I would just use the old caps and replace them if/when necessary, but since it will reside in Dallas, she does need something reliable.
I'll probably stick in some of the old caps long enough to get the thing running in the next few days, and then investigate permanent replacements with new stock. Since the replacements will all go under-chassis, and in any case she is not interested in the guts inside the radio, no need to re-stuff old components.
« Reply #8 on: July 30, 2011, 12:08:07 AM »
Here ya go..........
sales@hayseedhamfest.com
NØJMY
« Reply #9 on: July 30, 2011, 12:46:38 AM »
Don,
       Also check Mouser and Digi-Key. Screw the can type. look for the axial or radial lead types. They usually carry several brands, look for the ones that are cheapest. Usually you can find 10@450, 22@450 and/or 33@450 for just a few bux each. 47uF seems to be the point where the price rises sharply. Hayseed usually has pretty good pricing, but it doesn't hurt to look around.
If you are putting them under the chassis, it really doesn't matter what they look like. The canned multi section type seem to be somewhat a specialty item and are always a bit pricey. I also sometimes find good deals at hamfests. I usually keep
50 -100 "in stock." One of the first things I do when repairing old gear is to replace the filter caps, and then any other wax caps that are anyway tied to the B+ line.
Even the screen bypass caps. If it's a waxed paper cap, it's outa there! ! !
« Reply #10 on: July 30, 2011, 03:33:58 AM »
The one time I reformed electrolytics was on a Hallicrafters SX-11.  I shoulda known better.  They lasted about a year, then shorted and smoked the power tranny.
I agree 100% with the strategy of using only new caps.  NEVER use old caps, NOS or not.
« Reply #11 on: July 30, 2011, 04:28:48 AM »
Yep, the only thing old electrolytics are good for is restuffing if you want to make it look like year one.
N8ETQ
Mort
« Reply #12 on: July 30, 2011, 06:51:19 AM »
NØJMY
  Or   www.hayseedhamfest.com  fredricksburg, Ia.
« Reply #13 on: July 30, 2011, 08:50:13 AM »
The caps I buy from Mouser are either the Xicon/Lelon (house brand) or Nichicon. Axials are more expensive than radials but I use both; a Lelon 47uF 450V radial is $1.85. DigiKey and others carry similar stock. If ordering from Mouser ask for USPS First Class Mail for light packages otherwise the default is UPS, their delivery is real fast and there is no minimum.
Ive heard a few horror stories about the no name Chinese lytics from that Canadian outfit. If you just have to go that route dont run them more than about 2/3 of the voltage listed.
« Reply #14 on: July 30, 2011, 09:12:31 AM »
I think IC (Illinois Capacitor) is a good brand in electrolytics.  Look for iC as a logo on the side of the cap (if you have an assortment to chose from at a fest for example and want to avoid the stuff from China).
« Reply #15 on: July 30, 2011, 12:57:39 PM »
Where are these caps manufactured?
« Reply #16 on: July 30, 2011, 01:24:22 PM »
I use a lot of non-polarized caps by Solen from AES.  They are bulletproof, and come in very useful uF & V rating for power supply rebuilding.
BTW, if anyone is restoring an old BA and the can types are missing, I have hundreds of NOS ones and may have the style you need.  Free. Wink
« Reply #17 on: July 30, 2011, 08:22:48 PM »
On an island
« Reply #18 on: July 30, 2011, 08:31:33 PM »
On an island
Oh yea, that's the one. I should have known!
« Reply #19 on: July 30, 2011, 11:02:29 PM »
This is what I find on the Mouser web site for 20 mfd/450v electrolytics.  I must be overlooking something.
pricing (USD)
1:    $25.15
5:    $23.68
10:    $21.31
25:    $18.94
50:    $17.76
100:    $17.16
200:    $16.57
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/_/N-75hqt?P=1z0wqrdZ1z0vl82&SAP=true
« Reply #20 on: July 30, 2011, 11:30:06 PM »
Try 22 mfd/450 volts. They start at $1.23
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/_/N-75hqt?P=1z0wrkiZ1z0vl82
« Reply #21 on: July 30, 2011, 11:30:36 PM »
Try 22 uF, Don.  20 uF is no longer a standard value part and will be much more expensive.  'Lytics are very low tolerance, sometimes -20%/+100% so you're very safe with a 22 uF.
Mouser has a bazillion of different choices for around a buck each.  Go for the 105 degree caps instead of the 85 degree.
« Reply #22 on: July 30, 2011, 11:46:36 PM »
I do miss the days of getting a hardcopy paper catalog from Mouser and Digi-Key.
Sometimes the new is not always as good as the old. It made it a lot easier to thumb through the catalog and find what you wanted (and compare pricing at a glance) their on-site search utilities are not always your friend.
KA0HCP
« Reply #23 on: July 30, 2011, 11:50:56 PM »
The electrolytics I got from Just Radios are "Miec" brand made by Ling In Electronics of Taiwan.  Being concerned about the quality I tested a bunch of all the types, tubular, dipped mylar, electrolytic and silver mica.  All of them have tested spot on as marked.  I've got no complaints so far.
« Reply #24 on: July 30, 2011, 11:57:16 PM »
Thanks for the tip.  I hadn't even thought about any distinction between 20 mfd and 22 mfd capacitors. I just assumed anything in the ball-park of 20 mfd would be about the same. Actually, one of the originals was 8 and the other 16mfd. I had a bunch of 20 mfd ones in the junkbox and those are the ones I re-formed with the capacitor checker, so 20 mfd popped in my mind with no further thought, for new replacements. When repairing an old radio, I often use twice or more filter capacitance than the original.  Before WW2, capacitance was hard to come by, and high value capacitors were expensive when they were available at all, so lower capacitances were almost universally used for economic, not technical  reasons.
Many pre-WWII transmitters used something like 2 mfd oil caps as power supply filters for the same reason. The dynamic regulation of those power supplies when used for CW transmitters and class-B modulators was atrocious, and often a cause of audio distortion and key clicks, but most hams of that day didn't have an oscilloscope to look at their waveforms, so ignorance was bliss.
