June 01, 2024, 03:37:09 AM *
Author Topic: LDG DTS6&6R Control Cable  (Read 1874 times)
TA4AU
« on: October 26, 2010, 01:39:23 PM »
I must make new control cable for my switch about 40-50 Meter. can i use thin cable or must use thick cable (1.5 mm.) its important cable thicknees ? original ldg control cable is thin its sufficient ?
and i to take same descent line control cable and antenna coax its problem any interface rfi ? i tx radio and dts6r get stupid ?
I hope understant my bad english  Undecided
N8ETQ
Mort
« Reply #1 on: October 26, 2010, 11:14:28 PM »
Hello,
here is a Link to Alpha 2400C cable specifications.
http://export.farnell.com/_/dp/1619556
Looks pretty light...   24 AWG
From the switch manufactures.
"the remote has been tested up to 150 feet using quality Alpha 2400C cable."
http://www.universal-radio.com/CATALOG/switch/4672.html
"its important cable thicknees ? "
   50 meters = 165 feet
   If there "Braggin' " about 150 feet that may mean that it only worked
99.8% of the time at 200 feet.   If it gives you trouble you could add 20 or 30
feet of heavy wire between the control box and the run to the switch
to get back into spec.  It's a Crap shoot.
GL es 73
Dan
TA4AU
« Reply #2 on: October 27, 2010, 11:16:34 AM »
Tnx for reply i contact LDG Product and send me alpha2400C cable datasheet but idont understrand 2400C write diameter 4 mm. its total diameter or only one cond diameter ? . i think one cond about 4 mm. its very hard cable.
* 2400C-Alpha-Wire-datasheet-203.pdf (75.43 KB - downloaded 141 times.)
Page created in 0.03 seconds with 17 queries.
