April 29, 2024, 01:43:23 AM *
Author Topic: Help LK800 Power Pak Hook up??  (Read 1669 times)
rich
« on: October 24, 2010, 02:11:52 PM »
Hi, I have a LK800 with internal supply, I recently got the external power pak for it. The external power pak has a connector that goes in back of the amp. I put on connector and no extra volts. So I took off top cover and see two connectors that are not connected to anything. One has two wires which are green and the other connector has two wires yellow.  If I take connetor off internal power supply, then one of these conectors will fit there.
But both of the connectors that are not connected are two pin and if I disconnect the 4 pin off internal, Not sure how this works?
Please help. Thanks Rich
« Reply #1 on: October 25, 2010, 03:43:33 PM »
I have that amp here. Mine is an ISM model with the big power pack. Not sure which power pack you have. There was a document on how to install this power pack. I dont have it.  Mine came this way.  However, the manual for the LK800 is online. I have the original copy.  If you cant find it, Let me know.
