April 29, 2024, 06:32:29 AM *
Author Topic: sold - Ling TP-850 amplifiers  (Read 4159 times)
« on: September 22, 2010, 09:33:02 PM »
Ling/LTV 850 watt shaker table amps. The rating is conservative on them.
Output voltage: 34V RMS/47.6VDC MAX
Output current: 30A RMS MAX
Balanced transformerless output (bridge).
There is a 0-30A meter on the front measuring output current.
The two I have working here make this power:
1 Ohm - 900W
1.6 Ohms - 722W
2 Ohms - 578W
2.6 Ohms 433W
AC isolated input frequency response: +/-0.5dB 15Hz-10KHz
AC isolated input impedance >4000 Ohms
AC input voltage 2V RMS max. for rated output
DC input frequency response DC to 10KHz
DC Input impedance 1500 Ohms
DC input voltage 1V RMS +/-10% for rated output
DC ofset drift <17mV for AC line and load change, 10-45 DEG C
Distortion <0.5% 5-10000Hz
Noise and hum 80dB below rated output
Rear fan 650CFM
Heat rejection 6850 BTU/Hr max.
dissipation capability: 2000W max continuous, (1000W DC to 50Hz)
width: 19"
Height: 10.5"
Depth 25"
Weight 125 Lbs
It is a beast. A green color, like Altec green bit a little lighter. Might be good for a subwoofer system @1 Ohm or more, a bipolar servo DC supply, or as a modulator for a decent size TX.
An impressive feature is a crowbar protection that dumps the power supply and trips the front panel breaker. This has several inputs from various locations in the amp, and the circuit of the amp is simple enough to put in place other less annoying means of protection against clipping or overcurrent. It is mainly there to protect the shaker table 'voice coils' because harmonics from clipping would damage them.
All major assemblies unplug and come out for repair.
condition:
not working, repairable. IIRC 4 pcs that were complete enough to test, +1 for parts.  One may be missing the sheet aluminum covers. Just sheet, so this is not an issue to replace. They are sitting in a rack and I have to make space. I am keeping the rack.
$35 each
$25 for the parts unit if other units are bought
$150 for all.
Manual is here:http://www.bunkerofdoom.com/lit/ling_TP850.pdf (25 MB)
I will not ship these because of the weight. They can be picked up in Dallas, TX
« Reply #1 on: December 09, 2012, 09:09:50 PM »
sold or withdrawn
