May 07, 2024, 05:15:59 PM *
Author Topic: Collins 390 455 to 12 khz converter  (Read 2304 times)
iw5ci
I love old radios
« on: August 19, 2010, 01:45:28 PM »
Using a 455 to 12 khz converter is it possible to receive a good quality ssb using a pc software that works on the downconverted 455 khz if and have software dsp filters and multimode detectors or those converters work only with drm software?
« Reply #1 on: August 19, 2010, 01:50:00 PM »
The conversion to 12 kHz is done only so that the signal is in the frequency range of a typical computer sound card. Once you've converted the signal to 12 kHz and connected it to you computer sound card, you can use any of a large number of software packages to filter, demodulate and display the signal.
Have fun.
« Reply #2 on: August 19, 2010, 03:58:46 PM »
Check out Soft Rock on Yahoo. There are a number of software packages that are free. Flex Power SDR can also be used and allows you to set it up with a 12 KHz offset.
