May 08, 2024, 05:05:19 PM *
Author Topic: Mosley TA-33 WARC Dipole  (Read 7172 times)
AB3FL
« on: July 22, 2010, 10:32:37 AM »
I will ask here, since the REAL experts are on this board.
How does the WARC dipole connect on a TA-33? Is it wired across the existing driver or does it use a sleeve feed?
thanks
Tom - AB3FL
« Reply #1 on: July 26, 2010, 10:59:20 AM »
 I am unaware of this product, got a link?
AB3FL
« Reply #2 on: July 26, 2010, 11:37:34 AM »
http://www.mosley-electronics.com/spec%20files/amateur/srwarckit.htm
« Reply #3 on: July 26, 2010, 12:28:17 PM »
call technical support?
too bad they don't have downloadable manuals...
AB3FL
« Reply #4 on: July 26, 2010, 01:00:45 PM »
I did actually call Mosley.  They said it connects to the main driver with phasing lines.  I would like to builld my own dipole add on for at least 17m and maybe also 12m.  I am trying to avoid paying the $350 for the add on from Mosley
Tom - AB3FL
« Reply #5 on: July 26, 2010, 01:07:48 PM »
Ah!
Well Mosely's matching system is "trick" - assuming they use the same matching system, you'd need to copy their dimensions exactly... other than that, i dunno! Cheesy
Maybe someone else reading has some insights...
« Reply #6 on: July 26, 2010, 02:18:53 PM »
Have you tried something as simple as Google: "adding WARC bands to tri-bander" or "adding WARC bands to mosley tri-bander"
AB3FL
« Reply #7 on: July 26, 2010, 02:46:48 PM »
Of course!    and found nothing.  I am trying to use the same feedline for both.  Anyone can put  up a WARC dipole with a separate feedline.
Tom - AB3FL
« Reply #8 on: July 26, 2010, 03:22:06 PM »
You might tackle it from the point of view as to how to feed multiple dipoles from a single feedline rather then specifically how to interface your "TA-33" with a WARC dipole add-on.
« Reply #9 on: July 26, 2010, 03:50:19 PM »
You see them Prices Shocked
Pull that Junk down an put up an all-band dipole fed with Balanced ladder line an solve all the issues.  Cheesy
Put your money an your work into a good Balanced Antenna Coupler.
Jack.
