November 26, 2025, 08:14:41 AM *
Author Topic: Wow ! Check this homebrew from France - F6BIR - very impressive  (Read 4187 times)
« on: June 02, 2010, 07:24:58 AM »
This transmitter was built by Rene, F6BIR.  It is a very impressive construction job indeed !  Looks like a complete rig - with the D104 plugged into the front panel.  I'd sure like to hear this thing on the air sometime.
Rene has a blog at: http://f6bir.over-blog.com.  It's in French and I don't read much French anymore, so I had a bit of trouble getting everything that was written.
This is an 8 MOSFET class E rig using the same boards that Tom JJ and Brent used.  Very nice work indeed!
« Reply #1 on: June 02, 2010, 11:35:59 AM »
WOW
I'm jealous. I would never have the patience.
« Reply #2 on: June 02, 2010, 02:01:30 PM »
dunno, reads fine for me... Cheesy
http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF-8&sl=fr&tl=en&u=http://f6bir.over-blog.com/&rurl=translate.google.com&usg=ALkJrhiFzAGwB2dqeIDfOWvPHLlfyKewBg
Nice one, how much carrier power will that do??
« Reply #3 on: June 02, 2010, 08:39:37 PM »
I'm not exactly sure of the carrier power.  There are 8 MOSFETs in the RF amplifier, however they are smaller (considerably) than the FQA11N90 (only 500 volt devices as opposed to 900 volts).   So, Rene is running the RF amplifier at a reduced voltage.  I believe he gets around 200 watts, which is about right for the lower voltage - and keeping the same current.
Anyway, interesting to see what others are doing around the world.  I just sent out 3 more kits to other countries:  One to Australia, one to Canada and one to France.  I've sent kits to England, the Netherlands, several to Canada, and at least one other to Australia.  There are probably other countries, but I don't remember at the moment.
I have sent out over 100 kits since the start of this thing - although I don't hear 100 class E rig on the air... they may be  out of communication range with New England.  New ones come out of the woodwork from time to time..and some people have several transmitters....
« Reply #4 on: June 02, 2010, 10:01:07 PM »
Nice looking rig but I bet his driver chips run hot. I use 4423s in my 160 meter rig to drive the predrivers. 200 watts from IRF540s is pretty good power on 75. I run just over 300 with 14- IRF840s
