May 05, 2024, 05:42:48 AM *
Author Topic: FL DX 400 TWINS  (Read 1736 times)
ki4ndb
« on: May 21, 2010, 09:19:07 PM »
 just picked up the fl dx 400 & the fr400 receiver, wandering if anyone has any helpful insite on these twins.not really familar with this set up any & all help is welcome. thank you very much for your time.73's
« Reply #1 on: May 21, 2010, 09:40:46 PM »
I have a pair with the FLDX-2000 amp. On mine I replaced the filter caps in both units, cleaned and lubricated the transmitter fan, and cleaned the wiper contacts on the VFO capacitor in each unit.  I also did a by the book alignment.  The only problem I found was the CW mechanical filter suddenly turned into an attenuator; it was from the foam inside the filter deteriorating and was fixed by removal/cleaning of the foam residue.  I haven't had any problems with the other filters but I have a feeling they are similarly constructed and subject to the same problem.
It sounds OK on AM but you must adhere to the stated power.  I don't know if the final cooling fan is standard or optional but the finals definitely need air cooling.
Overall, these are a sharp looking station with lots of shiny chrome.  The 6 and 2 meter converters are too noisy for serious work but they do work.
« Reply #2 on: May 21, 2010, 11:11:17 PM »
foxtango.org
