If your going for it, go "full size"....
Maybe extend the present meter & illumination wiring to a stand alone meter in a project box and place it where you like.
Or place a larger meter where the speaker is in a dummy panel or in a salvage FRG-7 speaker grill from a parts radio so you keep the emblem and stock look. ( I would go that route )
Then use a matching Yaesu or other external spkr. for better audio also.
Both options would be reversible and give you many more meter options.
When you do it, post pics or a vid.
As to the best meter value / matches, I bow out to the board
Blah blah blah blah, Good luck. Dylan
Look at all the Real Estate in there......
http://images.google.com/imgres?imgurl=http://www.rigpix.com/yaesu/frg7_top.jpg&imgrefurl=http://www.rigpix.com/yaesu/frg7.htm&usg=__wvx-AO7x4MBmbvEHEgSJR70vtYU=&h=889&w=900&sz=199&hl=en&start=3&um=1&itbs=1&tbnid=dXybB3uJuAQs9M:&tbnh=144&tbnw=146&prev=/images%3Fq%3DYaesu%2BFRG-7%26um%3D1%26hl%3Den%26sa%3DN%26rls%3Dcom.microsoft:en-us:IE-SearchBox%26tbs%3Disch:1
