May 10, 2024, 02:55:01 AM *
Author Topic: Don KYV - try this on  (Read 7502 times)
« on: March 28, 2010, 05:43:46 PM »
Don,
still framed this off the video - thought you might like a new avatar pic. If the board wont take it due to sizing, I'll size it as needed. I dont know what the maximums are to fit.
KX5JT
John-O-Phonic
« Reply #1 on: March 28, 2010, 06:05:54 PM »
I like it! Hep Cat!
AMI#1684
« Reply #2 on: March 28, 2010, 06:57:41 PM »
Me too Grin
« Reply #3 on: March 28, 2010, 08:42:11 PM »
Yes, that would be a good one.  I haven't changed the one I have on now for years out of procrastination, and the one time I tried to modify it, for some reason I couldn't get it to work.
As you probably know, the one I have now is cropped from one of the photos you took the first time you were here.
Maybe I should name N3DRB as my official photographer.
I need a tutorial on how to change the avatar.  I think last time the board had just installed new software and I couldn't get it to accept the change.  That was a few years ago, and the old photo must be 10 years old now.
« Reply #4 on: March 28, 2010, 09:27:24 PM »
lets see- you have to go your profile tab up above and go to forum profile information, and choose upload your own photo, after downloading it to your machine first.
maybe someone knows what he maximum pixel count is the board will accept for an avatar. that way I can just size it.
I was trying to see how much video I could salvage from the original tape. someone who shall remain nameless taped over the master.  Cry
KX5JT
John-O-Phonic
« Reply #5 on: March 28, 2010, 09:54:36 PM »
I just always use MS Paint because there's a stretch/skew function that you can specify x and y as percentage.  I would reduce each time like 90% on both horizontal and vertical until it accepts the size, figuring within 10% is good enough. Smiley
AMI#1684
David, K3TUE
Per-spiring AM'er
« Reply #6 on: March 28, 2010, 10:51:32 PM »
IIRC, max pixels for your Avatar is 150h x 100w.
And yes, MS Paint is a good tool for this.
You can use Image / Attributes to find the current size.
Calc the percent reduction needed.
And use Image / Stretch/Skew to make it so.
And check it with Image / Attributes before you save it.
The attached image should save fine as an avatar.
David, K3TUE
« Reply #7 on: March 29, 2010, 12:36:33 AM »
Don, forget about changing your avatar.  It is nearly impossible.  I tried changing mine for a long time.  never could get it to work.  I gave up until Al W1VTP figured out a way and saved the day.  If you pull your avatar off and try to put it back you won't be able to.
Rob
« Reply #8 on: March 29, 2010, 01:30:47 AM »
I couldn't load mine to begin with.  Huh  Finally I E-mailed it to Gary INR here at the forum with a request and he did it for me. Smiley
D
KX5JT
John-O-Phonic
« Reply #9 on: March 29, 2010, 01:40:01 AM »
Rob
Wow, I found it not to be too difficult, you just have to have it within the size requirements....
AMI#1684
« Reply #10 on: March 29, 2010, 01:53:04 AM »
i think as long as the longest pixel size of the photo is less than 150 vert and 100 horizontal in size its easy. I found I had to scale mine 1 pixcel under the limit or it would not work.
went to 99 pixels by 99 pixels, worked on the first upload no problem. you have to undersize it by 1 pixel under the maximum limits for it to work.
« Reply #11 on: March 29, 2010, 08:24:10 AM »
D
ya, i found out most avatars were loaded by 3rd party, Gary or someone else.  the hassle of getting whatever software is needed to figure out the pixel is not worth the trouble.
WB3LEQ
« Reply #12 on: March 29, 2010, 09:13:00 AM »
I sorta prefer Don's new picture over the old one.  To me the new one is a lot more warm and friendlier looking than the old one.
Bob  WB3LEQ
Keep America Beautiful - Smash an ICOM!
« Reply #13 on: March 29, 2010, 10:10:20 AM »
I remember installing the original one was no problem, but that was when the board was using the previous software. Later, I tried to change it, but eventually gave up - not worth the hassle.
« Reply #14 on: March 29, 2010, 02:22:20 PM »
Yea I'll agree. Don musta been pissed about something that day. Prolly about some school kid smoking in the boys room.
Phred
« Reply #15 on: March 29, 2010, 03:13:37 PM »
Check out mine Smiley    Just uploaded it.  Not to hard.  Just has to be small.  You can open the picture in paint, Then use the size feature.  Put in 50% and 50%.  Then it will cut it down. Keep doing that until its small enough to upload.
« Reply #16 on: March 29, 2010, 08:20:20 PM »
Yea, he doesn't look anywhere near as "grizzly" ! ! ! ! !  Grin  Grin
« Reply #17 on: March 29, 2010, 08:36:00 PM »
Just goes to show what retiring from the rat-race can do for you.
« Reply #18 on: March 29, 2010, 10:18:28 PM »
don,
download the version 3TUE put on for you, that one will work fine. then go to profile in the menu bar and then to forum information. check the I will upload my own picture box , then choose file, then select the file you want to upload nd push upload ile button.
Even a rube like me can do it.
Am I really your official photographer? I gotta put that in my sig.  Cool
« Reply #19 on: March 30, 2010, 09:40:31 AM »
It worked.
Derb has been designated as my Official Photographer.
« Reply #20 on: March 30, 2010, 10:31:12 AM »
Don,
You look so happy that you may even talk to a slob bucketer!!!
Its gotta add 10db to your already strong signal!!
Derb, you did a good job taking that picture!
Joe, W3GMS
« Reply #21 on: March 30, 2010, 10:40:20 AM »
Don,
Actually, Derb, my Official Photographer, caught that shot just at the moment when we overheard Double-you Eight No Balls pissing 'n moaning about the AM'ers being so strapping that he was gonna have to shut down his ricebox and go to bed.  Grin
« Reply #22 on: March 30, 2010, 01:45:47 PM »
thats actually a still frame from the "visit with K4KYV' video that has been uploaded back to my youtube channel.  Cheesy
