July 30, 2026, 12:52:43 AM *
Author Topic: Hamwaves.com RF Inductance Calculator  (Read 13426 times)
aa5wg
« on: January 27, 2010, 08:47:20 PM »
Hi to all
At the bottom of the RF Inductance Calculator located at Hamwaves.com  ( http://www.hamwaves.com/antennas/inductance.html ) Self-Resonant Frequency is listed.  The calculator states 1/4 (parallel) self resonant frequency of n=0 sheath helix mode.
If I build/design a coil using this calculator and the listed self-resonant frequency is in the ham bands or close to the ham bands is this bad?
Chuck
« Reply #1 on: January 27, 2010, 09:21:42 PM »
Wouldn't it be a good thing if it were self resonant at the operating frequency? That is a cool page.
What Z has the coil? In plinking, I'm not seeing near 50 ohms at a resonant frequency, but I don't know how to use the tool yet!
aa5wg
« Reply #2 on: January 27, 2010, 09:37:15 PM »
I am building a tank coil for the link antenna coupler. i.e. One coil will be used on several band, 160 - 30 meters.  If there is a self resonance close or inside one of the bands is this bad?
Chuck
« Reply #3 on: January 27, 2010, 10:02:43 PM »
Not necessarily bad but may cause tricky or touchy tuning.
« Reply #4 on: January 27, 2010, 11:55:16 PM »
I misunderstood what it was for.
« Reply #5 on: January 28, 2010, 09:35:10 AM »
In most cases you would short out some turns on the coil as you move higher in frequency, so the self-resonance would also change and move higher.
Chuck
aa5wg
« Reply #6 on: January 28, 2010, 12:21:13 PM »
Is there a rule-of-thumb how far below self resonance I should operate the output tank coil.  This coil is for a link antenna coupler.
Both parallel and series feed will be used.
Chuck
aa5wg
« Reply #7 on: January 29, 2010, 10:28:39 PM »
Opcom, WB3HUZ:
Thank you.
Chuck
