May 13, 2024, 06:59:53 PM *
Author Topic: Come on Folks, 5KW Collins still avail  (Read 12914 times)
« Reply #25 on: January 16, 2010, 03:00:03 PM »
oh go ahead dave. you got mad skillz, you'll make something FB out of it all.  Cheesy
K6IC
« Reply #26 on: January 16, 2010, 03:07:43 PM »
Yea must be 4X5's.   The Mod Trans is oc course,  the grey can,  usually in oil at this level.  Nice Heising reactor,  guess the HVPS choke is in another bay ... or can it be cap input ?  That would not be very common.
Think all of the 820 series rigs had SS drivers.  4X5 only needs abt 25 watts drive for 5.8 Kw out,  and so on.  73  GL  Vic
« Reply #27 on: January 16, 2010, 04:32:39 PM »
Look at the yellow PCB stickers on the cabinet door and all the capacitors. The doorknobs even appear to have stickers too!
My Gates had them too.  I removed them and plastered them all over my rusty S-10 pickup.
Why is the power company everywhere so anal about providing 3Ø power?
« Reply #28 on: January 16, 2010, 04:47:36 PM »
On the hockey pucks too? Maybe yours used the older brown micas.
K6IC
« Reply #29 on: January 16, 2010, 04:57:48 PM »
WB3LEQ,    " ...  and with a minimum charge of around $100 per month at 0 KWH's use."
Guess that I'm lucky.  My workshop has 3 Phase,  and the meter charge has gone up to about $15/mo @ 0 Kwh.  It is Center-tapped Closed  Delta,  which is neat cause you have 240 3 phase and 120/240 Split Phase simultaneously.
Think that I was also wrong about there being two Vac Variables,  can only see one, and the row of fixed  caps probably means that there is only one variable,  or mabe it is hiding.   Vic
« Reply #30 on: January 16, 2010, 08:04:42 PM »
ONE HOUR THIRTY-FIVE MINUTES LEFT.............................
« Reply #31 on: January 16, 2010, 08:34:04 PM »
There 's a lot of good stuff in there--all those 1 MHz mica caps, the modulation reactor, oh man, AM bc rigs are manna from heaven.  The gift that keeps on giving.  Then there's the meters, the hardware for mounting the vac caps, the h.v. wire, relays, the lower level audio stages, ... it   just     doesn't      end.
K6IC
« Reply #32 on: January 16, 2010, 09:19:24 PM »
Over and done ... No bids.  The plot thickens.
Vic
« Reply #33 on: January 16, 2010, 10:21:57 PM »
Who is going to contact the seller?
"real tubes have handles"
