May 24, 2024, 05:09:16 PM *
Author Topic: Old style microphone connector  (Read 7005 times)
Barrie
« on: November 26, 2009, 02:18:56 PM »
I'm in need of a microphone connector.  I don't know what it's called.  It's vaguely similar to a PL-259, but without the pin.
Instead of a center pin, it has a solder glob right in the center of insulating material.  It threads onto the mating connector on the chassis.  It's two connector.  The outer portion is ground.
What's the name of this connector?
73, Barrie, W7ALW
KA8WTK
« Reply #1 on: November 26, 2009, 02:32:26 PM »
My old catalogs call it a "single button" connector. My DX-100 and some of my test equipment uses that connector.
Bill
Bill KA8WTK
N3WWL
« Reply #2 on: November 26, 2009, 02:39:32 PM »
I've seen others make a button connector from a PL-259.
Barrie
« Reply #3 on: November 26, 2009, 03:36:35 PM »
Thanks!
That "two button" description led me to a boatanchor site with a bunch of information, including the part number.
Mouser has them in stock, so I'll be able to order tomorrow.
73, Barrie, W7ALW
ve6pg
« Reply #4 on: November 26, 2009, 05:34:19 PM »
...just use a pl259...shave down the centre pin, using a grinder, or whichever...
..sk..
N0WEK
« Reply #5 on: November 27, 2009, 03:16:55 AM »
I know the company make lots of different connectors, but I've always seen them referred to as "Amphenol plugs".
There is one on the headphone connector on the old CD radiation survey meters. I always grab any of those plugs when I can.
KX5JT
John-O-Phonic
« Reply #6 on: November 27, 2009, 08:53:25 AM »
I believe you are refering to the button microphone connector.  I also heard them called a "dot connector".  Mouser has them.
Switchcraft makes them.... part number 2501F
see http://www.switchcraft.com/products/connectors-53b.html
http://www.mouser.com/ProductDetail/Switchcraft/2501F/?qs=sGAEpiMZZMukzO2buB5fmxBDCHCUIqUhkZcaFyutvpk%3d
My DX-60 and Viking I use it.
AMI#1684
kg8lb
« Reply #7 on: November 27, 2009, 12:08:44 PM »
PM your address I will send you one. I have a few hundred of them here !
« Reply #8 on: November 27, 2009, 05:19:46 PM »
And of course the Apache and Lunchboxes and TV and RF generators - and even meters.
Barrie
« Reply #9 on: November 27, 2009, 09:53:13 PM »
I tried to PM KG8LB, but the message was blocked.
73, Barrie, W7ALW
kg8lb
« Reply #10 on: November 28, 2009, 07:59:56 AM »
73, Barrie, W7ALW
  Hmmm ?
 My email is kg8lb@comcast.net
« Reply #11 on: November 28, 2009, 09:17:37 PM »
In the Bogen days we called them "high impedance mic connector"
Barrie
« Reply #12 on: November 28, 2009, 09:48:02 PM »
Fred:
That's what I'm working on, a Bogen PA amp, using a pair of 807s!
Will make a nice speech amp once I drain the hum out.
73, Barrie, W7ALW
kg8lb
« Reply #13 on: November 29, 2009, 08:10:59 AM »
PDF : http://www.switchcraft.com/products/connectors-53b.html
  A pretty handy connector as the cable end is bi-gendered. You can unscrew the retaining nut from the connector and join up with another cable end to end.
  PM is fixed. Will get a few out in the mail. Sorry abt the mix-up.
Page created in 0.038 seconds with 18 queries.
