Title: Old style microphone connector Post by: Barrie on November 26, 2009, 02:18:56 PM I'm in need of a microphone connector. I don't know what it's called. It's vaguely similar to a PL-259, but without the pin.
Instead of a center pin, it has a solder glob right in the center of insulating material. It threads onto the mating connector on the chassis. It's two connector. The outer portion is ground. What's the name of this connector? 73, Barrie, W7ALW Title: Re: Old style microphone connector Post by: KA8WTK on November 26, 2009, 02:32:26 PM My old catalogs call it a "single button" connector. My DX-100 and some of my test equipment uses that connector.
Bill Title: Re: Old style microphone connector Post by: N3WWL on November 26, 2009, 02:39:32 PM I've seen others make a button connector from a PL-259.
Title: Re: Old style microphone connector Post by: Barrie on November 26, 2009, 03:36:35 PM Thanks!
That "two button" description led me to a boatanchor site with a bunch of information, including the part number. Mouser has them in stock, so I'll be able to order tomorrow. 73, Barrie, W7ALW Title: Re: Old style microphone connector Post by: ve6pg on November 26, 2009, 05:34:19 PM ...just use a pl259...shave down the centre pin, using a grinder, or whichever...
..sk.. Title: Re: Old style microphone connector Post by: N0WEK on November 27, 2009, 03:16:55 AM I know the company make lots of different connectors, but I've always seen them referred to as "Amphenol plugs".
There is one on the headphone connector on the old CD radiation survey meters. I always grab any of those plugs when I can. Title: Re: Old style microphone connector Post by: KX5JT on November 27, 2009, 08:53:25 AM I believe you are refering to the button microphone connector. I also heard them called a "dot connector". Mouser has them.
Switchcraft makes them.... part number 2501F see http://www.switchcraft.com/products/connectors-53b.html (http://www.switchcraft.com/products/connectors-53b.html) http://www.mouser.com/ProductDetail/Switchcraft/2501F/?qs=sGAEpiMZZMukzO2buB5fmxBDCHCUIqUhkZcaFyutvpk%3d (http://www.mouser.com/ProductDetail/Switchcraft/2501F/?qs=sGAEpiMZZMukzO2buB5fmxBDCHCUIqUhkZcaFyutvpk%3d) My DX-60 and Viking I use it. Title: Re: Old style microphone connector Post by: kg8lb on November 27, 2009, 12:08:44 PM PM your address I will send you one. I have a few hundred of them here !
Title: Re: Old style microphone connector Post by: WU2D on November 27, 2009, 05:19:46 PM And of course the Apache and Lunchboxes and TV and RF generators - and even meters.
Title: Re: Old style microphone connector Post by: Barrie on November 27, 2009, 09:53:13 PM I tried to PM KG8LB, but the message was blocked.
73, Barrie, W7ALW Title: Re: Old style microphone connector Post by: kg8lb on November 28, 2009, 07:59:56 AM I tried to PM KG8LB, but the message was blocked. 73, Barrie, W7ALW Hmmm ? My email is kg8lb@comcast.net Title: Re: Old style microphone connector Post by: flintstone mop on November 28, 2009, 09:17:37 PM In the Bogen days we called them "high impedance mic connector"
Fred Title: Re: Old style microphone connector Post by: Barrie on November 28, 2009, 09:48:02 PM Fred:
That's what I'm working on, a Bogen PA amp, using a pair of 807s! Will make a nice speech amp once I drain the hum out. 73, Barrie, W7ALW Title: Re: Old style microphone connector Post by: kg8lb on November 29, 2009, 08:10:59 AM PDF : http://www.switchcraft.com/products/connectors-53b.html (http://www.switchcraft.com/products/connectors-53b.html) AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
(http://www.mouser.com/images/switchcraft/lrg/2501F.jpg) A pretty handy connector as the cable end is bi-gendered. You can unscrew the retaining nut from the connector and join up with another cable end to end. PM is fixed. Will get a few out in the mail. Sorry abt the mix-up. |
