Also works well. Another trick when using the jigsaw or the "sawzall" type devices is this. When you clamp it down, sammich your piece of work between two pieces of wood. I'm not an engineer, and I can't tell you why, but it really helps the cuts come out cleaner. No chance of kicking out or at you, either.
Good idea for safety. The sandwich will keep the work piece from flexing or lateral movement, thus preventing binding and causing a kick-back.
It appears most accidents occur cuz the work doesn't flow straight and true - and without flexing. The clamped down sandwich appears to handle both problems. Otherwise, the blade gets a grip on the binding work and all hell breaks loose, as well as creating shoddy cut lines.
Because of this thread, I'm gonna be REAL careful and take new precautions with my table saw. I kinda thought my few bad experiences were random, but evidently it's a real hazard to avoid.
