May 02, 2024, 08:00:03 PM *
Author Topic: antenna height.....  (Read 16676 times)
KC2IFR
« on: October 26, 2009, 08:13:10 PM »
Most of us know how the height of an antenna (dipole in this case) affects the performance but Im wondering what is the affect on  the receiving performance and can this be plotted.
Thanks,
Bill
« Reply #1 on: October 26, 2009, 08:15:29 PM »
The book I read says reciprocity
KC2IFR
« Reply #2 on: October 26, 2009, 08:16:44 PM »
k
« Reply #3 on: October 26, 2009, 09:00:41 PM »
Yes, the antenna will usually have the same pattern on transmit and receive. But you can have an antenna with tons of loss (e.g. Beverage) that would be a terrible transmit antenna and a fantastic receive antenna. When you throw in ionospheric and noise factors, especially on the lower HF bands, reciprocity doesn't strictly apply.
Bill, what are you looking to do? Improve reception of relatively close-in signals (a few hundred miles) or longer distance stuff? Are you trying to optimize in one direction (or maybe reduce noise or QRM from one direction) or do you want better receive in any direction? What band(s)?
« Reply #4 on: October 26, 2009, 09:06:03 PM »
(Looks like Huz beat me by 6 minutes...  Grin)
Hi Bill,
As you know, height affects the vertical take off angle of a dipole for both RX and TX.
Then there's the specialized receiving antennas.  TX/RX reciprocity works here too, but receiving s/n is enhanced.
Take a beverage. It might have an overall loss of -20 db compared to a dipole. It's a terrible transmitting antenna. But even though it's down -20db from a dipole, when receiving, the s/n ratio is improved. ie, The desired signals and static noise all drop -20db, but the static noise drops even farther than -20db, resulting in a better listening antenna, also due to directivity and f-b..
So, bottom line is a low height above ground (6'-7' high) can actually improve our abilty to hear desired signals when using the right antenna.
For a dipole, there isn't much improvement in receive s/n ratio when lowering it close to the ground. It just gets deaf. We need to construct a wave antenna (bev) or other loop style antenna (K9AY) to see results.
Hope that covers what you were wondering about?
« Reply #5 on: October 26, 2009, 11:24:46 PM »
If you don't have room for a beverage, a rotatable loop, maybe around six feet diameter and tuned with a variable cap from a cheap transistorized AM bc rx is supposed to make a pretty good rx antenna.  Even better is supposed to be a pair of 10 or 15 foot tall insulated poles about 50 or 60 feet apart and phased with a variable phasing network.  I have not tried any of this myself but want to (someday).  DX Engineering makes and sells all the stuff for the phased receive whips but I wouldn't be surprised if the information for making all of that yourself is somewhere on the internet.
Rob
KC2IFR
« Reply #6 on: October 27, 2009, 06:23:41 PM »
Thanks guys for the info.
Steve as u know because of the lack of real estate I only have a 75meter dipole up about 40 ft.
I know when I plot the ant using eznic the pattern on 75 shows what is expected, a real cloud burner!
I got to thinking (big mistake) about if the antenna receiving pattern was the same. In other words, does the antenna receive signals better if the signals were coming down to the antenna rather than from the sides if u get what I mean. That assumption seemed silly to me so I posted the question.
And JJ......your explanation makes a lot of since .
Thanks again,
Bill
« Reply #7 on: October 27, 2009, 08:27:17 PM »
Thanks again,
Bill
Bill,
I better understand what you’re axing…  Since you're playing wid EZNec, you probably already know this - if so, then maybe it will help someone else...
An antenna is like a round balloon filled with air. You can squeeze the balloon at the sides and make a standard dipole figure-eight pattern, or form it into a squash and make it a directive Yagi pattern. It’s all done by phasing. (by adding elements, etc)
There’s two views of an antenna – the horizontal and the vertical views. To view the horizontal pattern requires an on-top or bird’s eye view of the pattern. Your dipole at 40’, as well as any dipole at any height, will look like a figure 8 from on-top. That’s why we want the broadside facing our favorite direction and the side nulls away.
The vertical pattern is best viewed from the sidewalk. Picture your 40’ high dipole’s vertical pattern as a light bulb standing on its socket. Much of the energy is beamed (or received) straight up.  This doesn’t mean you don’t receive lower angle energy from farther away stations – it’s just that this energy is down 10-15 db from your higher angle energy. Remember the balloon analogy?  In your case you have squeezed it so it forms a figure 8 from a bird’s eye view and forms a light bulb facing up from the side view. (actually TWO light bulbs slightly tilted, facing opposite directions)
The vertical pattern (light bulb standing on its socket) can be lowered towards the horizon simply by raising the height of the antenna. However, the horizontal figure 8 pattern changes very little with height.  We need to add an extra element or two to change the bi-directional dipole horizontal figure 8 (two directions) - into a unidirectional lobe. (one direction)
Hope this helps.
kd4afp
« Reply #8 on: October 27, 2009, 08:45:03 PM »
Good visuals, Tom
Rick
« Reply #9 on: October 27, 2009, 10:24:47 PM »
The old ARRL antenna book had good drawings of dipoles in the horizontal and vertical planes.  They also had graphs of one at different heights above ground which graphically displayed the lobes Tom is speaking about.  Don't know about the modern Antenna Books, because little has changed and my 1956 book is still valid.
Tom is lucky he has the room to play with added elements on 75 and 40.  I can hear him down here in the South of Oklahoma quite well when the band is open and he is phased toward me.
« Reply #10 on: October 28, 2009, 08:56:26 PM »
Thanks for the report, Jim.
Yep, you're located right in the western path of the pair of 75M delta loops at 190', Jim. It's now switchable to the west.
I'd like to get on this weekend and work some coast to coast AM. I'll do a post here when I do and maybe we can talk.
The last time I tried it a month ago it started out well with some west of the Miss River stations and even Bill in Colo called in. Calif never showed cuz we didn't stay on late enuff.
Maybe the corndix will be good enuff to do it soon.  We like to make the transmissions short and get as many stations involved as possible.  As long as we keep axing for new DX AM check-ins and everyone keeps the  comments brief, it works out FB.
« Reply #11 on: October 28, 2009, 10:13:35 PM »
Daughter's birthday and anniversary so will not be around the radio this weekend.  However, with me hearing WWV @ 2.5 until nearly 10 AM and starting at about 3 PM says we are going to have at least moderate to long distance this winter.
If last night on 160 is any indication, you will have a gooooood time.  75 was so long that I couldn't hear stations within a 500 mile radius of my home after 8 PM last night and the night before.  A storm front with possible severe storms is due tomorrow night and it will work its way East Friday and Saturday.  We shall see.
« Reply #12 on: October 29, 2009, 04:34:27 PM »
I have a 10 meter vertical on a tower.  Its about 85 ft up.  Many times, It is the clear winner for RX over my Double Zep horizontal at 55 ft.  Last night I had two rigs on listening to 3885. One on the 10 meter vert and one on the Zep.  The peak signal was very close.. Within 5 DB.  The noise on the Zep was S9.  The noise on the Vert was S1.  Big difference.  It allowed me to actualy hear a couple of you guys on this forum that like to run a HUGE carrier with almost no audio Smiley
Clark
« Reply #13 on: October 29, 2009, 07:25:06 PM »
Those death antennas are killer.
The 10 meter vertical probably had less noise because it’s far enough off of the ground away from the majority of all man-made interference and the fact it’s probably somewhat death because its way too short for 75 meters, but its high enough to still receive signals.
« Reply #14 on: October 30, 2009, 12:36:47 PM »
You can compensate if they excite a low angle death ray
« Reply #15 on: October 30, 2009, 12:54:38 PM »
My SUPER Death Ray 10M antenna Did it again!    I heard a Certain Board member with his HUGE carrier and Low audio on last night again..  Was able to pull him out on the 10 meter Death ray.  Then another board member came on and about blew my speaker out.. LOL.
Whats neat is I can use BOTH antennas at once and fade between them. This seems to really help Smiley
The 10MDR is really neat on Noisey nights!
Its interesting listening to East coast stations now that the band is longer.  You guys really hold the key down.. LOL.  I was doing some work and thought it would be fun to Time some of you guys.  The winner was 31 minutes!!!!   Now thats an old buzzard! Most seem 10 to 15 minutes lock down keyup is normal.  Different style as to what takes place over Here.  More of a Say what you want to say and unkey type of Round table.
Clark
« Reply #16 on: October 30, 2009, 12:55:31 PM »
Those death antennas have a fatal flaw, though. Cheesy
Sounds like you're simply trying to determine if the reception you get now is to be expected, Bill?  If you're looking to improve your reception over what the dipole yields but are space restricted as you seem to be saying, check out the receiving set up that Steve uses at his place. It consists of a pole maybe 10 feet high with wire loops attached. Takes up minimal space, but sure helps pull out the weak ones. Rather than boosting the signal greatly, it instead cuts down the noise considerably. Signals in the static suddenly become good copy.
« Reply #17 on: October 30, 2009, 01:25:15 PM »
I will have to look into that. I wonder if I could use my Inverted L for that purpose?  Any plans for making such a tuner?
« Reply #18 on: October 30, 2009, 01:56:53 PM »
I saw an MFJ box that used a seperate antenna to null noise out.  I will do some research.  Sounds like a neat project!
« Reply #19 on: October 30, 2009, 02:13:02 PM »
Clark:
The MFJ box is good for nulling out local noise/interference (crap from your neighbor's computer or plasma TV), but is generally not good for removing noise propagated in from a distance, like lightning static, etc. THis is because the angle of arrival for the distant stuff is not constant, so you could have it nulled out for a second and then the null is gone. Locals stuff is groundwave and very constant, so the nulling works.
Some 160 meters guys have used the MFJ box or similar to enhance a particular signal, but even then the results are transient. So, setting and forgetting is not likely to happen.
Invest your time/effort in a good directional receiving antenna or antennas. You'll be shocked how much better you can hear.
« Reply #20 on: October 30, 2009, 03:10:19 PM »
Thanks for the advice.. How about this system nulling the Guys Pool pump in the summer?  That would be great!
I dont have the room for Directional antennas on the low bands.  I am pretty much maxed out with my Zep.  One can dream though.
« Reply #21 on: October 30, 2009, 03:28:07 PM »
Clark:
Nulling out T-storms? Correct... it's like trying to hit a moving target. I guess it's cuz T-stoms often are in many different areas at once.
Jay/W1VD sent me some torroids and other small parts about a year ago. I built up a phasing unit that would take two 50 ohm antennas and phase them from 0-180 degrees, respectively. I used the NE quads and the west Yagi on 75M.  I could null out radio signals to beat the band. Could drop them into the noise. But the T-storms were a nightmare. I'd get a moderate null, then the next crash wud come in max strength. I'd null that one and then it wud change again. Plus, try to null a static burst!!  It takes an impossibly fast reaction... Grin
The DSP stuff out there today is also about useless for static crash nulling, so I figggered if this method worked, I'd have quite the receiving edge. But alas, there appears to be no method for nulling out T-storm crashes. Maybe someday a sophisticated neural network will do it. But for now we must use our own between the ears, caw mawn.
« Reply #22 on: October 30, 2009, 03:58:19 PM »
Collins made a little unit that plugged into the 75S series of radios for noise cancelling.  It monitored ~ 50 Mc because they found that local spikes and such were stonger there.  The best thing I have found for static is a rotatable loop or beverage.  Usually the station I want to work is located near 90 degrees from the noise, and either the loop or beverage will help reduce that noise.
« Reply #23 on: October 30, 2009, 04:32:07 PM »
Yep, agreed, Jim.
I found the best lightning suppressor is a SINGLE antenna with a big front to back.
Why a pair of phased antennas (as I described in my previous post) will not do the same trick, I dunno.  I mean, a Yagi is a set of phased elements that rejects lightning noise off the back and the rejection stays stable - why shouldn't a pair of phased separate antennas do the same with a similar pattern?  Doesn't make sense to me.
For example, tonight I hear 75M is very noisy to the west with what sounds like lightning crashes. When I switch to the NE, the noise drops a good 12-15db.  I can hear both ambient AND crashes that are similar in attenuation.   Using a pair of phased antennas with the phasing box will null signals, but not the crashes.
I must be thinking something incorrectly.
All I can figure is that the Yagi's vertical pattern off the rear is fairly broad - while the phased antennas are a sharp null, thus unstable.
« Reply #24 on: October 30, 2009, 04:39:44 PM »
I have tunability.  One antenna is into the main RXer.  It has bandwidth and filter shift.   The vert is on the other sub reciever with inrad filter.  I can then MIX in any mount of each antenna.  Kinda neat.
I noticed that some stations really come in strong vert.. While others come in strong on the horizontal antenna. Probably because of the antenna type the other station is running?
I am not much of a DXer so all of this is really kinda pointless.  It would be nice to Null out local noise in the neighborhood.  Thats all I was thinking about really.
I also realized that the vert was running the reciever at wide open.  While the Horizontal had its preamp off.  This accounts to why the signals where close to the same peak on both antennas.  The vert was on a strong reciever and the horizontal was on a weak one.  Still.. The noise is MUCh much less on the 10 meter Vert.
Page created in 0.103 seconds with 19 queries.
