December 03, 2025, 08:23:55 AM *
Author Topic: 1W of AM?  (Read 4376 times)
VE3GZB
« on: October 26, 2009, 11:36:57 AM »
On which band would it carry further under current atmospheric conditions? 40m or 80m?
Reason - until the tubes arrive for the modulator of my 100W Xmitr, I have to make do with a small 1W rig I put together.
73s
geo
VE3GZB
« Reply #1 on: October 26, 2009, 02:15:11 PM »
Great antenna; either band. On CW and a decent antenna, you can work the world with milliwatts of power on 80 and 40.
VE3GZB
« Reply #2 on: October 27, 2009, 09:37:26 PM »
I have a lousy antenna (and no room to improve upon it) so 1 watt isn't cutting it in evenings.
What is the best time for 40m? I ask because by 8pm EST there's an awful lot of noise (80m is much worse here though, barely anything gets through on 80).
Maybe if I can try 40m again during less noisy hours, I might make a contact.
73s
geo
VE3GZB
Ed/KB1HYS
« Reply #3 on: October 27, 2009, 11:03:59 PM »
that's double tough. QRPp and a poor antenna = much frustration.
I'd stick to 40M under those conditions.
you might try announcing a sched transmit time here and seeing who can hear you. If we know to look for a sig there is a chance someone on the board may hear it.
73 de Ed/KB1HYS
VE3GZB
« Reply #4 on: October 28, 2009, 09:16:16 AM »
Ok, I'll try again tonight around 8 pm on 7290, see if I can raise any contacts with just 1 watt.
73s
geo
KX5JT
John-O-Phonic
« Reply #5 on: October 28, 2009, 09:27:47 AM »
7.290 Mhz as soon as the sun is about to set till after it rises is wiped out by a Broadcast station.  No way I could pick up a 1 watt signal with such a beast riding on top of it.
Maybe you should consider finding an open frequency below 7.200 and then posting it here.
AMI#1684
VE3GZB
« Reply #6 on: October 28, 2009, 07:47:18 PM »
I'll fire up the shortwave and see if there's any vacant spots between 7.0 and 7.3, see if I can raise anything (though it's highly doubtful).
73s
geo
