July 18, 2025, 02:49:51 AM *
Author Topic: 4-400 screen modulation  (Read 4584 times)
KA4RFA
« on: September 28, 2009, 08:45:47 PM »
I'm just getting back into ham and I'm new to the forum.
I'm amazed at wealth knowledge of the forum members.  I have some questions.
I'm building a 50.4 AM transmitter using pair of 4-400's.  I do not have iron to plate modulate, so I want to screen modulate instead.  Has anyone done this?
Thanks!
KC4VWU
« Reply #1 on: September 28, 2009, 09:27:13 PM »
I know I'll probably get beat up over this, but let me make a suggestion; Cathode modulation. It's simpler, and you'll probably not notice much of a difference in the results.
73, Phil
« Reply #2 on: September 28, 2009, 09:51:32 PM »
Run it as a linear, less hassles and you will still have a respectable signal if your exciter has decent audio.
In the 60's I built up a 4-400A for mountain top contesting with a club and used it for AM, CW and SSB driving with a 10A and TX converter.
« Reply #3 on: September 28, 2009, 10:07:53 PM »
Carl makes a good point concerning simplicity and the ability to use it for other modes is definitely a plus.  I am pretty sure one of the ARRL handbooks carried a design for one.
Rodger
Jeff W9GY
« Reply #4 on: September 29, 2009, 03:51:36 PM »
Built a HB pair of screen modulated 4-400's several years back.  Modulation is introuced using a hi fidelity output transformer, wired hi-Z in series with adjustible screen supply. Low Z side of transformer driven by a "stick" solid state 10W audio amplifier. A little "kink"  in the envelope, but feedback not necessary. System works great, good fidelity...of course, not efficient, but for amateur use efficiency not a big deal unless you're into 'green'.
Jeff  W9GY Calumet, Michigan
(Copper Country)
« Reply #5 on: September 30, 2009, 08:07:52 AM »
Applying a little of the modulating voltage in phase to the control grid biass will get rid of the "kink" and make the modulated envelope waveform look like a plate mod rig. Been there, done that.
