December 01, 2025, 03:56:48 PM *
Author Topic: Identify this Modulation transformer  (Read 4625 times)
« on: July 08, 2009, 01:32:45 AM »
This one ran two 810s with HK54s.  Any idea of ratings?  Any idea what all 11 taps are?
Thanks as always!
Clark
K6IC
« Reply #1 on: July 08, 2009, 02:03:24 PM »
Hi Clark,
I do NOT know anything about this transformer,  but Peerless had a very good rep ... I've not Googled "Peerless",  but have read somewhere that they were a part of Altec or associated with Altec.
Have you Googled Peerless #######" ??  Often you can find some info this way.  Also there have been threads here regarding measuring Mod Transrormers.
EDT: - Just Googled   "Peerless modulation transformer"  The first hit had the fllg:
PEERLESS TRANSFORMER CATALOG AL-1285-1
PEERLESS TRANSFORMER CATALOG 1953
Am off the the remote site,  and you may have already Googled around,  but,  if not,  Google is your friend -
73,  and  UR GK sounds great here,  hope that you get the bigger rig going soon.  GL  Vic
« Reply #2 on: July 08, 2009, 02:11:46 PM »
Thanks Vic!    I did some more work on the GK and I got it runnig correctly with the D104 now Smiley  The 6sj7 was causing me lots of trouble!
I did a search but could not find much info it. I will try again. I was mainly searching for this part number.
Clark
KE6DF
« Reply #3 on: July 08, 2009, 02:40:35 PM »
So what is the Peerless part number. I have some old catalogs. but I need the part number
« Reply #4 on: July 08, 2009, 02:42:22 PM »
m-2107-t  Its shown on the last picture. Thanks alot!
Clark
KE6DF
« Reply #5 on: July 08, 2009, 11:53:38 PM »
It's not in my catalogs.
In googling around I found a Chinese site with one of these transformers for sale.
It said it was a 300 watt unit. No other specs.
You should be able to tell by the weight. I think a 300 Watt modulation transformer should weigh somewhere around 30-35 lbs.
Dave
« Reply #6 on: July 09, 2009, 01:39:10 AM »
I think this one is more like 500 to 600 watts.  Its 60 lbs.  Also. It ran 810s.  So that would point to the need of 500 to 650 watts.  I will have to measure all the taps to figure it out. Should not be that hard.  Thanks alot for your time and effort!
Clark
Page created in 0.043 seconds with 15 queries.
