December 02, 2025, 06:34:01 PM *
Author Topic: Stancor Info  (Read 4553 times)
Joe Moore
« on: August 12, 2008, 10:54:38 AM »
 Does anyone know of any websites with stancor info on them.
I have a couple of what I think are a Choke and one thats a Mod trans.
I pulled them out of some old military equipment, Vietnam era and I
think VHF but not sure, Its been to long to remember.
Numbers are:   CADF 301745
                     56C048
And:               CADF 301671
                      52C084
       Any help?             Joe KF0XV
« Reply #1 on: August 12, 2008, 03:24:38 PM »
Go Here:
http://208.190.133.201/xfm/index.html
WZ1M
« Reply #2 on: August 12, 2008, 03:29:14 PM »
The numbers 56C048 and 52C084 look like Hallicrafters part numbers.
Gary...WZ1M
Joe Moore
« Reply #3 on: August 12, 2008, 05:52:37 PM »
Well Gary it was out of a Hallicrafters. Thanks, I never
put 2 and 2 together...
                            Joe
WA1LGQ
« Reply #4 on: August 13, 2008, 06:15:09 PM »
    I found a A-4713 in my Ranger. Does anyone know if this is worth keeping in there or should I get it out of there and go phase inverter or better transformer?  Thanks.........Larry
« Reply #5 on: August 14, 2008, 08:32:59 PM »
What is your goal or requirement? Does the current tranny not meet your freq response or distortion requirements? If it does, rock on. If not, I'd say skip another tranny and go the phase-splitter route.
http://www.amwindow.org/tech/htm/rangtron.htm
WA1LGQ
« Reply #6 on: August 15, 2008, 06:36:11 PM »
       Hi Steve, I guess I should be asking if this transformer is better than the original. It is probably a cheap replacement and is not any better sounding.  I assume that the original failed at some point. I'm leaning towards the resistance coupled system anyway, I'm pretty sure that will sound better. But my junkbox has some other interstage transformers that may be a possiblility.  I have another modulation xfrmr that is rated at 40 watts and is much bigger than the original, but probably would be impossible to fit into the cabinet. This Ranger has been sitting around here for a long time, and I want to put it on the air finally. It basically works ok now, but needs some restoration and improvements. Its an older version, without the bias supply and keyer, so I will have to add new versions of those circuits. The bias supply is no problem, but I have not seen any ss version of the keyer circuit. Haven't given it much thought yet, but it should not be a real problem. When working, it will be part of the "bedside station", hopefully with its own antenna system. Looks like the circuit from the link would be easily duplicated. Only the negative feedback circuit would have to be a bit different with the other transformer if I use it.
            Larry
Page created in 0.064 seconds with 17 queries.
