May 18, 2024, 08:45:31 AM *
Author Topic: Signal Corps 1945 BC-1332 Transmitter  (Read 2930 times)
W9ZSL
« on: July 08, 2008, 05:42:27 PM »
 Huh Hi group! I have a friend who came up with a US Army BC-1332. I've had the very divvel of a time getting info on the thing. It still has original-issue tags and was found among some stuff the CAP was getting rid of several years ago here in northern Wisconsin. It is a definate Jeep-mounted and probably had a companion BC-1333 rcvr. The unit has one Weston 0-150 MA meter that does everything via a complex bridging switch. It is 11" high by 19 1/2" wide by 18" deep.  He wants to eBay it and I'm helping him out. Hey, who says two old Fahrts can't clean out a troubled garage?  Any word on this bird?  Mike Kuehl (ex-K9ZSL) Goal...ticket back by fall!  73.
N0WEK
« Reply #1 on: July 09, 2008, 02:37:39 AM »
I believe that that's the same as a BC-902 which is a marker beacon transmitter that transmits one of three tones on 75 mhz at about 3 watts.
http://en.wikipedia.org/wiki/Marker_beacon
W9ZSL
« Reply #2 on: July 09, 2008, 04:47:12 PM »
 Grin It's a LOT more than that! On inspection it has a built-in PA system that uses at least two military equiv. or even 4 "6L6" tubes with a modulator section and a batch of output tubes. This has a key and mic jack and is built as a driver to a higher-power stage of audio, public address or RF. It is modular as stage one. As a stand alone in a jeep, the beacon tracked the transmitter. The beacon is probably in there but so is an at least 100 watt AM/CW rig!
Da Mix
N0WEK
« Reply #3 on: July 10, 2008, 02:40:49 AM »
Here at least it's listed as a marker beacon transmitter and an improved BC-902.
http://pages.cthome.net/fwc/BC-EQP.HTM
These were built to run 24/7 so I'd say it'd be very overbuilt. The modulator section will modulate it with one of three different tones.
Page created in 0.031 seconds with 18 queries.
