May 02, 2024, 04:40:20 PM *
Author Topic: Transformer Question  (Read 3467 times)
N1ESE
« on: July 01, 2008, 04:31:03 PM »
I have a vintage modulation transformer that is excess to my needs and want to sell it.  However, before I do, there's some slight damage to it and I'd like to represent it properly.  Or, if it is junk as a result of this damage, I don't want to rip someone off.
If you notice in the pic below, what I will call bakelite here (I'm not sure what the material is) is broken.  However, I don't seem to note any problems when I check out the transformer with my ohm meter.  Is this still useable in this condition?
« Reply #1 on: July 01, 2008, 08:04:09 PM »
It doesn't look good, but I don't think it's a problem. One a test under high voltage would allow you to know for sure.
« Reply #2 on: July 01, 2008, 11:09:29 PM »
I don't think the crack in the phenolic would make any difference in its performance if that is the only damage.  I have used worse than that and just glued the terminal board back together with epoxy.
« Reply #3 on: July 02, 2008, 06:55:53 AM »
first of all, mod transformers are never "excess to your needs"!! One can NEVER have enough spares!!
As far as the damage goes, I have repaired worse ones that that. You just have to gently remove the end bell and fabricate a new insulating spacer out of phenolic and carefully reassemble it. If the windings are still good, that "damage" is no big deal.
N1ESE
« Reply #4 on: July 02, 2008, 08:18:06 AM »
Well, I'm never going to get around to building my own tube gear and finally coming to the realization and accepting it.
Thanks for the input.
« Reply #5 on: July 05, 2008, 10:17:42 AM »
I agree with Don. Looks cosmetic to me. The advantage to checking it with HV would be to state so and thereby get more $ for it.
