December 10, 2025, 10:53:50 PM *
Author Topic: Removal of old Masking tape........  (Read 18269 times)
wa2rqy
« on: June 25, 2008, 11:08:47 AM »
Yeah, you know the type, those guys that put masking tape all over the front panel with numbers, lines, etc. written all over them Angry
After x amount of years this tape is almost impossible to remove without scratching up the FP.
   I have been very successful with this method.
Lay the masking taped item horizontally(tape up), apply a nice thick coating of a Lanolin based hand cleaner from a can(not the gritty stuff) to the masking tape then lay a piece of plastic wrap, plastic bag, etc. over it so it does'nt dry out.
Leave it sit for a day, next morning just wipe it off Cheesy
   I have not tried this on wrinkle finish, and sometimes it changes the paint color  so very slight but becomes normal in a day or so.
I have used this method dozens of times on radios, etc that no body would buy at fests Wink
   Use this method at your own risk, try a small area first till you get comfortable with this method.
GL es 73.......
Rich WA2RQY/4
KF8XO
THIS SPACE FOR RENT.
« Reply #1 on: August 07, 2008, 01:22:20 AM »
WD-40 works too! Under the plastic makes it work quicker.
VE1IDX
« Reply #2 on: December 18, 2009, 07:48:26 AM »
I know it's late but this is what I use. It has the benefits of smelling like a fresh orange.
http://www.mgchemicals.com/products/836.html
Learn from others mistakes.You will never live long enough to make them all yourself.
Page created in 0.044 seconds with 17 queries.
