April 28, 2024, 05:13:54 AM *
Author Topic: Scream Modulated 4-1000A  (Read 23867 times)
w8khk
« Reply #25 on: June 18, 2008, 07:50:27 PM »
It is obvious that LOTS of planning went into the layout!  Cool bandswitching in the exciter.  Thanks for posting all the detailed pics.
« Reply #26 on: June 19, 2008, 07:34:03 AM »
I used up quite a few Sharpies worth of ink and a whole bottle of alcohol wiping it back off and redrawing it before I drilled the first hole. It sometimes gets pretty interesting trying to figger out exactly where everything wants to live.
I built it back in a time where my personal life was a little less complicated. It went from a thought / concept in my head to on the air in about 2 1/2 months.
Jeff W9GY
« Reply #27 on: June 19, 2008, 04:45:10 PM »
Great FB looking rig!
Sure wish I could do the type of metal-work.  I'm quite happy with my pair of screen-modulated 4-400's.  I use a UTC hi-fi output transformer wired backwards, with the high Z side wired in series with the adjustable screen voltage.  I have plenty of audio power, supplied from a 20 W SIP solid state amplifier. It will cut the tubes off on negative peaks.  Yes, a little assymetrical without feedback, but after hearing it in the mod-monitor and good-off-the-air reports, I have left the global feedback out of the circuit.
Jeff  W9GY Calumet, Michigan
(Copper Country)
Page created in 0.036 seconds with 19 queries.
