May 06, 2024, 01:59:00 AM *
Author Topic: Thordarson Tranny Mystery  (Read 2595 times)
stevef
« on: February 16, 2008, 05:28:09 PM »
I have a Thordarson plate transformer that I cannot find any reference material for.  I dug through the Bunker of Doom material thoroughly.  The closest match in terms of looks, weight, and voltages is the T-19P68.   Mine is badged as T-41268 and has a 230v primary, with 6000 and 4900v secondaries with common C.T.  What I'm really trying to find out is that the primary connectors are bolt lugs on top of an insulator of some sort that can switch like a DPST switch when the nuts are loosened.  What is this switching function for?
« Reply #1 on: February 16, 2008, 07:49:00 PM »
It's difficult to find  data on Thordarson transformers.  They frequently changed their product line, and assigned new type numbers to all their products, even those that were not subject to any change in design.  It can be frustrating to have several catalogues, and none of them list the transformer you are looking for, but you would about have to have every year's catalogue from the time they started manufacturing to be able to find them all.  I have seen identical transformers with completely different part numbers stamped on the nameplates.
stevef
« Reply #2 on: February 16, 2008, 08:22:07 PM »
Well after shining a penlight in the narrow gap of the side plate, I was convinced there was no 'switch' action going on.  There is a heavy retainer spring on the underside of the insulator that was responsible for the feeling of a switch.  Duh. Tongue
« Reply #3 on: February 17, 2008, 12:06:19 AM »
strapping! put that into a rig.
