May 03, 2024, 12:31:15 AM *
Author Topic: Tower Gurus, Help!  (Read 4210 times)
« on: January 30, 2008, 04:29:39 PM »
I'm trying to identify a tower. It's a Rohn but I have not found any other identification on it. It's triangular, each face is 30 inches, and the vertical supports are 1.5" OD pipe. It is made of 20 foot sections that bolt together with flanges that are 4" x 4" and 5/8" thick. There are four bolts on each flange and they are 5/8" OD. The diagonal support struts are made of 5/8" OD pipe and are spaced 22 inches. They bolt to flanges on the vertical pipes with 3/8" x 1-1/2" bolts. As configured, there are 4 sections for 80 total feet and it's free standing.
It looks similar to Rohn 80 series but all of the dimensions are smaller. Anyone have an idea?
« Reply #1 on: January 30, 2008, 04:43:58 PM »
Sounds like 65G, except it uses 2" O.D. pipe.
You sure it's Rohn?
From their catalog:
The 65Gfeature 2" outside diameter high strength steel side rails and is built using a 26-1/4" equilateral triangle design.  The Zig-Zag® cross bracing is formed from a continuous 5/8" solid steel rod electrically welded every 22" on the side rails.
WA1HZK
« Reply #2 on: January 30, 2008, 04:47:19 PM »
I sent your request to Radian Engineering. I'll post the results here ASAP. By the way. I have all of the old ROHN catalog available on line so you guys can print out any data you need. The Radian stuff is there also.
One of those things I'm into.
www.criticaltowers.com
Keith
WA1HZK
www.criticalradio.com
www.criticalbattery.com
www.criticalresponder.com
« Reply #3 on: January 30, 2008, 04:57:25 PM »
TNX gents. It is a Rohn - there's the remainder of a tag.
The cross bracing on the tower in question is bolted to the side rails, not welded. Maybe it's an older version of 65?
Lots of good stuff on Keith's site!  Still looking.
KA1ZGC
« Reply #4 on: January 30, 2008, 08:18:52 PM »
While you're there, take a look at the pics he took at Tim's. The TV translator tower is 65G, IIRC, and it sounds almost exactly like what you're describing. I think there's at least one close shot of it.
Bill, KD0HG
304-TH - Workin' it
« Reply #5 on: January 30, 2008, 09:09:19 PM »
A picture would be good, Steve.
WA1HZK
« Reply #6 on: January 31, 2008, 12:48:41 PM »
From the Parts ID Dept. of Radian/ROHN:
Doesn't sound like anything I know about........ does it taper or is a straight tower ?   Can you provide any pictures ?  Why do you think it is a Rohn ?
Keith
WA1HZK
« Reply #7 on: January 31, 2008, 01:42:29 PM »
I'll take some photos and post.
Thanks for your efforts thus far.
K6IC
« Reply #8 on: January 31, 2008, 02:18:40 PM »
Hi Steve,
I do have some 65G at the remote QTH  ...  Think that it is about 26-inches on a face,  and this is all welded,  four-bolt flanges in 10 and 20-foot sections ... have the DS on another computer ... by the time I get out there to measure it  U will know all about the tower in question.  The bolted braces seem novel ... wonder if that was some military knock-down thing or something ??  73  Should be a nice tower,  whatever it is.  73  Vic  K6IC
