April 29, 2024, 01:30:24 AM *
Author Topic: Transformer Question  (Read 2686 times)
Dan N3SMF
« on: October 04, 2007, 01:45:14 AM »
Hi all.. I have a hunk of iron here and was wondering if it could be useful in a rig project. The iron is some kind of control transformer with a 2400v primary and a 120V secondary. I am under the assumption that transformers can be run "backwards" in certain applications, and I have done it in audio and small power applications.  If this is the case it might be a prospect for a future project. Am I assuming wrong or are there any other limitations that need concern me?  Further specs on the tag say it is rated a 5kva 60cycles continueous..any input will be appreciated.  Thanks  Dan
Syracuse Radio W2INR
« Reply #1 on: October 04, 2007, 06:33:51 AM »
How big is it Dan?
SWLR-RNŲ54
Dan N3SMF
« Reply #2 on: October 04, 2007, 07:05:48 AM »
  Hi Gary,  Probably around 50 lbs.
« Reply #3 on: October 04, 2007, 08:23:16 AM »
Hookd up backwards with a full wave bridge rectifier, it would make a nice plate transformer for a leanyour or HB rig. Using the T.I.T. formula (10w per lb) it should be good for at least 500w or better.
