May 14, 2024, 10:37:24 PM *
Author Topic: anybody have a 4-1000a datasheet?  (Read 5030 times)
kf6pqt
« on: August 30, 2007, 10:22:55 PM »
In pdf? That shows which pin is which?
Thanks,
Jason
W6IEE, formerly KF6PQT
« Reply #1 on: August 30, 2007, 11:15:03 PM »
Tube data is all over the Web, including for the 4-1000. Google is your friend.
kf6pqt
« Reply #2 on: August 31, 2007, 01:18:35 AM »
Actually, not so much out there for the 4-1000a, or the y448, hence why I asked.
I usually look to Duncan Amps, then google, but hadn't had much luck.
« Reply #3 on: August 31, 2007, 01:31:32 AM »
A Google search using the terms "4-1000 Tube Data"  yielded
http://www.radiowrench.com/sonic/so02018.html
http://www.g8wrb.org/tetrodes.php
http://www.qsl.net/nt8n/project.htm
on the first three links. All of them had complete 4-1000 data sheets. Google is your friend.
« Reply #4 on: August 31, 2007, 03:13:21 AM »
And then there's Frank's Electron Tube Data Sheet Database. Here's Sheet 4:
http://frank.pocnet.net/sheets4.html
kf6pqt
« Reply #5 on: August 31, 2007, 12:30:09 PM »
Hmmm, google was not so much my friend for adding the "a" in 4-1000a, go figure.
Thanks again!
-Jason
kf6pqt
« Reply #6 on: September 01, 2007, 07:16:58 PM »
The 110 degree heat here is whats whipped me!
I have many, many parallel projects, and not nearly the time.
« Reply #7 on: September 02, 2007, 10:12:38 AM »
Did the DX-100B whip you and you've gone to another project now?
Mack
I think it kicked his butt!!  Grin  Grin
kf6pqt
« Reply #8 on: September 02, 2007, 02:16:37 PM »
Nope, nope, too hot to ride the bike... I have something I'm going to try today on the dx-100, hopefully this nails it!
But yes, I heated up leftovers for lunch Friday by tossing the freezer bag out onto the patio concrete. Yesterday afternoon, Because it was 110, I broiled some sausages with nothing but solar radiation... Put 'em in pyrex dish, wrapped it up good with some cling wrap, set it all on a black-painted piece of metal, and aimed a mirror at the top of of 'em... 20 minutes later it smelled like I had the grill going out there. Hour and twenty later I brought 'em in with a potholder, the edges were browned!
Page created in 0.058 seconds with 18 queries.
