June 21, 2025, 08:12:20 PM *
Author Topic: WHAT R U USING IN UR AUDIO CHAIN?  (Read 25563 times)
ve6pg
« on: August 27, 2007, 09:29:28 AM »
...hi from tim....i'd like to know what folks are using in their audio chain, to produce the nice smooth audio, that makes AM so nice to listen to...kinda like a poll, i assume..
...sooo..what's the deal?..
N6WDR
N6WDR World Domination Radio
« Reply #1 on: August 27, 2007, 10:15:42 AM »
HI Tim,
This is a list of items I use on my Valiant.  I went the cheap route, if you want to call this cheap lol.  I use all Behringer equipment.
Heil PR40
T-1953 - Tube pre-amp
DEQ2496 - EQ
MDX2100 - Composer  Noise gate/Compressor
REV2496 - Reverb
Richard N6WDR
SSB is for Sissy's... AM Is For Real Men
« Reply #2 on: August 27, 2007, 10:19:59 AM »
KO6NM's DAP610, and an Altec EQ to pull the high end down.
http://wa3vjb.amham.com/sound/VJBatAPE-440-8kc.mp3
« Reply #3 on: August 27, 2007, 12:58:54 PM »
Microphone: D-104 into 10 megohm load, mixed with Electrovoice Dynamic mic. Either mic may be used alone or mixed in phase with the other.
Homebrew tube-type 2-channel audio mixer/preamp with switchable in/out pre-emphasis curve in each channel
Switchable passive low-pass audio filters: sharp cutoff @ 3400~/ more gradual cutoff @ 5000~/ flat response
Urei Modulimiter - (the only solid state unit in the audio chain) AM broadcast compressor/peak limiter
Homebrew transmitters (with 100% broadcast quality audio iron) or Gates BC1-T (160m only).
All units in the chain are interconnected via 500-ohm balanced audio line.
W2XR
« Reply #4 on: August 27, 2007, 01:46:06 PM »
Microphone: An RCA 44-BX ribbon, an RCA 77-D ribbon, or an Electro-Voice RE-27 dynamic. I like the sound of the 44-BX and the RE-27 the best.
Microphone Preamplifier: Modified Ampex 351 record-playback amplifier. All triode from the input to the output. The Ampex has an unloaded microphone input transformer, which the ribbon microphones require for best performance. I also have an Ampex MX-10 tube mixer available, but I don't normally use this.
Equalizer: Rane Professional 30-band
Orban Optimod-AM Model 9100A Audio Processor, configured to roll-off at 12 Khz.
Homebrew transmitter,with 100% broadcast quality audio iron from both a Gates BC-1J and a BC-1F. The audio driver is also homebrew; it consists of a pair of class A push-pull 845 drivers in self-bias and with 1200 VDC on the plates, driven by a pair of triode-connected 6J7s, and a pair of 6J5s. HV rectification is provided by a pair of 866As. The 845s are transformer-coupled to a pair of class B 833As with shunt-regulated bias. There is 6 dB of global negative feedback from the plates of the 833As to the input stage of the audio driver.
All of my audio, from the microphone input to the input to the 845 audio driver deck, is connected via a 600-ohm balanced audio line, with full patch-bay connectivity using old WE-241 audio patchbays. Gain structures set by Daven 600/600 ohm adjustable T-pads.
Bruce
W8KHZ
« Reply #5 on: August 27, 2007, 05:42:13 PM »
I'm using a D-104 microphone, a microphone cable and a microphone connector.
Brian - W8KHZ
Currently running a big homebrew transmitter (pair of 250THs modulated by a pair of 810s) paired up with a National HRO-50.  I also run a BC-610-I / NC-2-40D combo which is a lot of fun too.
Catch you on 75M AM!
« Reply #6 on: August 27, 2007, 05:51:11 PM »
Sometimes a PA-42:
« Reply #7 on: August 28, 2007, 08:05:38 AM »
Pete,
       So thats why you always sound like you have a clothespin on your nose Grin Grin
W9GT
« Reply #8 on: August 28, 2007, 08:18:58 AM »
Brian - W8KHZ
I have the same audio chain Brian!!  My D-104 is a "Silver Eagle"!  That makes it sound better.  Grin
73,  Jack, W9GT
73, Jack, W9GT
« Reply #9 on: August 28, 2007, 09:04:58 AM »
Noise Cancelling Boom Electret (like Madonna)
Common Base Bipolar Preamp
TL082 Op Amp Bas Treb
6SN7 in place of mic XFMR , 6V6, 811's (ART13) and feedback
Mike WU2D
« Reply #10 on: August 28, 2007, 05:08:00 PM »
Don you have the BL40 ?
Wow that takes me back.
Did you leave the automatic phase switch in place?
A station I worked at bypassed it after we traced a certain whoomp sound to whenever it did its thing. Supposedly it switched input phase based on some sample of program material as a way to maximize assymmetry.
Syracuse Radio W2INR
« Reply #11 on: August 28, 2007, 06:05:26 PM »
The line up here:
EV 27ND microphone
Wheatstone SP5 production console
Dorrough DAP 610
Class "A" audio driver in the transmitter coupled to a class "B" modulator, modulating a class "C" amplifier. I guess that makes it a "ABC" rig!
SWLR-RNØ54
Mike/W8BAC
« Reply #12 on: August 28, 2007, 06:56:23 PM »
Rode K2 large diaphragm tube type condenser microphone
Collins 212B2 7 input, all tube mixer.
Orban 672A combination graphic and parametric equalizer.
Berhinger DSP 2024P Virtualizer Pro
Orban Optimod 9200AM processor
k3zrf
« Reply #13 on: August 28, 2007, 09:08:19 PM »
EV 27ND mic
Rane VP-12
Autogram AC-8
Dorrough DAP 310
DBX 160 to audio chain....drives ssb, AM "C"...........EQ broken.
dave/zrf
Ian VK3KRI
« Reply #14 on: August 28, 2007, 10:01:34 PM »
 I'm upgrading the weak link in my audio chain by doing some voice-over training . Does that count?
        Ian VK3KRI
« Reply #15 on: August 29, 2007, 12:11:49 AM »
Marshall V-63M large diafrizm cheap chinese condenser mike, Behringer VX-2000 voice processor, bypassing the first stage of the speech amp and jacked into the second stage.
I kinda like to keep it as simple as possible. And besides the VX-2000 has more than enough knobs and switches to twiddle with to get it right!!
« Reply #16 on: August 29, 2007, 07:19:57 AM »
The only store-bought piece of equipment in the entire audio chain is the microphone - a Behringer B1.
Everything else is homebrew.
You *really* only need a few things to make your signal sound REALLY REALLY good.
A good mic (condenser recommended) which feeds -
a flat mic preamp, which feeds -
equalization, then feeding -
a fast attack peak limiter (this is very important), and finally feeding -
a negative peak limiter (which may be part of the transmitter, but should be included), and finally -
the transmitter frequency response should be reasonably flat with high modulation capability.
Trying to "gain limit out" the occasional high negative peaks results in an otherwise poor sounding signal because lots of peak limiting is required to do this.  Just include a negative peak limiter as part of the transmitter, or if the transmitter will pass VERY low frequencies (or DC) such as a class E, PWM, Flex, etc. transmitter, put the negative peak limiter ahead of the transmitter - but ONLY if the transmitter is a really good one - else included it *after* the modulator (perfectly valid application of a negative peak limiter).
I hear way too many overprocessed stations on the air.  Too much limiting/compression/procession *IS* distortion - it is modifying the original audio signal.  Sure, *some* peak limiting is necessary to control the dynamic range, but really, if operated correctly, the processing should be transparent and not put artifacts onto the signal or otherwise make the signal annoying to listen to after a period of time.
Just my $.02
Steve W8TOW
« Reply #17 on: August 29, 2007, 09:11:35 AM »
Berhinger B1 Mic into a Berhinger mixer. side chain is a
Berhinger VX 2000 mic processor (which does just about everything!)
and a BBE Sonic Maximizer for Mic inputs...
This drives a HB speech amp, 6SJ7, 6N7, and a pair of triode connected
5881's
I only use this chain for one station.
The rest of my 8 stations, I just use a D-104, (properly phased)
into a properly designed speech amp...if 6V6's or 6L6's are used as
driver tubes, do triode connection or make sure that negative feed
back is used....
GL 73 steve
8tow
73  W8TOW
« Reply #18 on: August 29, 2007, 11:23:20 AM »
Chain?? We don't need no steenking chain!
Crystal D-104 into a 4.7 meg load -> 12AX7 amp -> 12AU7 inverter -> 6B4G x2 driver -> 810 x 2 modulator
I sound equally bad in person.  Grin
W9GT
« Reply #19 on: August 29, 2007, 11:31:35 AM »
You sound fine Todd!
There is something that I have observed with many stations running all of that "audio chain" processing gear.  When they get it all adjusted to where it sounds natural and the best, it sounds just like a D-104!
Sometimes, when adjusted to their specifications, not as good as a D-104.
73,  Jack, W9GT
73, Jack, W9GT
KA8WTK
« Reply #20 on: August 29, 2007, 12:37:51 PM »
B1 microphone --> VX200 --> Radio Shack solid state PA amp --> "backwards" audio output transformer --> grids of triode connected 813s
Bill KA8WTK
« Reply #21 on: August 29, 2007, 12:45:23 PM »
Steve QIX got me going with a Radio Shack condenser microphone suggestion a long time ago.
Take an 8" square chunk of plexiglass and drill a hole in the middle. Rear mount a condenser mic with contact cement. Mount the panel at a 45 degree angle into a wood base with rubber bumpers on the bottom.  This is what I used before the boom mic. and it sounded better but looked stupid. Come to think of it the boom mic looks stupid too.
Mike WU2D
Bacon, WA3WDR
« Reply #22 on: August 29, 2007, 01:15:35 PM »
Old Radio Shack unidirectional condenser mike - lately also a superdirectional RS mike originally meant for VCR work.
Old Radio Shack 5-band graphic EQ mike preamp - much modified filter Q and frequencies, also a series LC shunt dipping around 800Hz, that was needed for some reason.
2:1 asymmetrical peak limiter, with bass phase aligner and adjustable servo-clipper.  MPF102 JFET shunting audio for variable gain control.  3.5 KHz 2-pole Sallen-Key low-pass filter available for nighttime operation.  All solid-state.
Audio chain in TX: 7199 pentode-triode with triode operating as phase splitter driving a 12AX7 dual triode as cathode followers to the grids of two 8417s.  820 ohm 2W resistor from the screen grid of each 8417 to a 350V regulator (12BH7).  Mod transformer: Stancor A3894 wired for full pri to full secondary, orented for impedance step-up to the output.  About 8 to 10 dB of negative feedback from modulated B+ to the cathode of the pentode section of the 7199.  About 1V p-p needed for modulator input.  A small capacitor to ground from the plate of the phase splitter, to compensate for unequal leakage inductance in the halves of the mod transformer primary.  This reduces distortion above 5KHz.  (Would have been on the cathode instead, if necesssary.)
Modulated RF finals: two 6146 (A? B?), screens self-modulated with original screen resistor (20K if I recall) to unmodulated B+; only RF bypassing on the screens.  A small cap from screens, a few hundred pF, to modulated B+ to compensate for the screen RF bypass capacitance.
Modulator power supply: solid-state rectified, cap-input for about 975V for the modulator.
RF PA power supply: also solid-state rectifier, from the same winding, but original choke-input 600V for the 6146 plates.
« Reply #23 on: August 29, 2007, 02:36:50 PM »
Marshall MXL990 large con. mike
Tascam 4 channel M20 mixer w/ PE20 para EQ
Shure SE30 gated compressor/ mixer
K6JEK
RF in the shack
« Reply #24 on: August 30, 2007, 01:04:43 PM »
Shure SM58 rock and roll band veteran
Fender reverb unit, the one with the springs.   Just a little reverb, now.
Bogen PA amplifier
OK, OK.  Just dreaming.  That's what I hope to have some day.  I do have the reverb tank, thanks to Rockin Joe DVD.   But the rest is just a distant plan.   Until then I squeak along with a Heil PR40 and a Symetrix 528E into a class H/class E.   I get complaints all the time.   Too clean. Really.
Page created in 0.102 seconds with 19 queries.
