May 04, 2024, 07:58:00 AM *
Author Topic: QUESTION: Viking 1 PTT mod  (Read 2970 times)
David, K3TUE
Per-spiring AM'er
« on: March 05, 2007, 11:16:40 PM »
I want to add a simple PTT mod to my Viking 1.
I want to use a 12VDC relay (cheap and as close as RS), so I think I can use a voltage-doubler circuit off of the filament AC with perhaps a small dropping resistor to account for the output being double the peaks instead of double of RMS (so I have read).
Is it really as easy as using a DPDT relay and paralleling the 2 NO relay switches with the 2 switches in the plate power switch?
David, K3TUE
« Reply #1 on: March 06, 2007, 08:38:27 AM »
Pretty much!!
N2udf
« Reply #2 on: March 11, 2007, 02:59:54 PM »
Check out the info on Bama>It gives you all the details.....Lee,N2UDF.
« Reply #3 on: March 12, 2007, 02:21:04 PM »
As Frank said....... YUP !
Done just that in my Vikings 1&2.
