June 08, 2024, 08:57:20 AM *
Author Topic: Vacuum Variable Clamps  (Read 3900 times)
« on: December 20, 2009, 05:32:02 PM »
I was working on the rig today and almost dropped a vacuum variable when it slid out of the flange clamp. I thought it was tight. Anyway, does anyone know how tight (inch pounds) to set the 10-32 clamp screw so it holds the cap but doesn't break the seal. I have never seen that spec anywhere.  I have a 2 inch clamp on the 500 pf plate tune and a 3 inch clamp on the load cap.
« Reply #1 on: December 20, 2009, 06:46:22 PM »
YES! Please!  I have essentially the same cap.  Specs anyone?
Al
« Reply #2 on: December 20, 2009, 08:23:33 PM »
Al,
I have an email in to Jennings and will post the response when and if it comes.
I had both caps bolted into a plate and was trying to measure the right angle drive height. It fell right into my lap and would have hit the floor if the right angle drive wasn't attached. I bet this is the reason many new caps have the flange soldered to the cap or they are part of the cap.
k3zrf
« Reply #3 on: December 21, 2009, 07:08:38 AM »
I have used this source from time to time
http://www.mgs4u.com/Jennings-flanges.htm
dave/zrf
« Reply #4 on: December 21, 2009, 08:35:27 AM »
No Data there Dave.
k3zrf
« Reply #5 on: December 21, 2009, 08:39:48 AM »
Hmmmmmm, no drawings?
Start from there
dave/zrf
« Reply #6 on: December 21, 2009, 09:07:30 AM »
Dave,
I been there but no data on how tight to make the clamp screw.
« Reply #7 on: December 21, 2009, 12:43:41 PM »
At least it's a start
I'll check with some of my friends
Al
Rob K2CU
« Reply #8 on: December 21, 2009, 01:52:46 PM »
here's a listing for the CSVF-500 that may apply to your case:
http://www.jenningstech.com/technotes/csvfflng.shtml
6.0 to 6.5 In-Oz for single screw flange, 3.5 to 4.0 In-Oz for dual screw type.
« Reply #9 on: December 21, 2009, 02:35:11 PM »
TNX Rob, That is the cap and I assume the same number for the FM3 on the loading cap
Page created in 0.068 seconds with 19 queries.
