May 06, 2024, 03:10:39 AM *
Author Topic: Johnson 500 problem  (Read 2995 times)
Steve W8TOW
« on: July 25, 2006, 09:53:18 AM »
Hey Gang, got  one for ya to think about....
My Johnson 500 just developed a problem.
On CW, the keyer pot has no effect, but does have the OSC cuttoff, keying is fine, all bands
NO CHIRP.
On AM, the OSC no longer cutsoff (thus runs when UNKEYED now)
The keyer pot has no effect either AM/CW....
AM/CW BIAS is -50 VDC as spec...
The Keyer tube (12AU7) was found to have a open filment, but still after replacing it with a new
12AU7, the keyer circuit can not be adj....
SO....just  a run down, NO KEYER POT ADJ AM/CW (POT & TUBE IS GOOD)
CW GOOD WAVE FORM
AM OSC REMAINS ON IN STANDBY....
BIAS GOOD
any ideas???
73 steve
8tow
73  W8TOW
Steve W8TOW
« Reply #1 on: July 28, 2006, 12:11:30 PM »
 Smiley Smiley Smiley Smiley Smiley Smiley Smiley Smiley Smiley
Well, If you look long enough, ya can find anything!
Once I got the keyer working properly, I evaluated the interconnecting
cable between the PS & RF deck.
This cable carries AF from the driver, & the "hot" side of the CW key input, down to a
relay....In standby, the relay is open, and B+, AF, and the key line is open.
So....
the keyer circuit was sick
the cable was bad
AND one of the 4 contacts of the relay was touching all the time...it just happened to be
the key line contacts!
WOW, lot o work for just a small problem...
73 steve
8tow
73  W8TOW
« Reply #2 on: July 28, 2006, 12:58:26 PM »
          Be glad that you didnt have to go the trials and tribulations that I went through with the 500's cousin, the Invader 2000. I was one cigarette away from the
BFH and a gallon of gasoline!! Sometimes these things will totally test your patience and perseverance! However the end result is uaually the effort. It is now one of my favorite transmitters!!
