You can probably figure it out by working it in reverse:
- you know the Bs+ for the finals
- you know the secondary impedance
- you know the primary Bp+
- now you need to know the primary impedance
To make 100% modulation the rig will need to produce
2x Bs+ *peak* AC swing from the modulator tubes. So, depending on the drive (AB2 or AB1) we can make some sort of determination as to how much swing the mod tubes can make... but we can assume to start that they make full swing to the Bp+ rails...
Now we know the turns ratio of the transformer! It's the voltage ratio.
Plug that into the equation for impedance vs. turns ratio, and since we know the
secondary's impedance we can quickly determine what the primary is going to be in ohms!
Just look out for the PP primary and single secondary when spec'ing it...
_-_-WBear2GCR
