Thanks Pete,
There's a Peter Oldfield that has a program DX-AID that I have sent an email inquiring about his software. (
poldfield@compuserve.com)I got this info from the DXers antenna book by ON4UN. I don't know how old this book is, maybe 4yrs old, so this Peter Oldfield may not be doing DX-AID anymore.
There was a section in there about long and short path.
I also read that the long path can sometimes be 180 degrees opposite the short path, but then I read on that this long path is a seasonal thing too.
Very interesting happenings in the aether.
73..........Fred
This is from a review on eham.net:
Unfortunately, created at the time of MiniProp Plus and CAPMAN, DXAID runs in DOS protected mode and uses the EGA Hicolor resolution with all constraints of this environment. For example, a runtime error 207 ejects you from the system if you don't validate the current conditions before to run the forecast ("Forecast" menu, Set Current conditions). But it is as much a programmation error not handled by the system as an user error who wants to go faster than the system in "cutting corners" of the validation process, Hi !
DXAID is available in two DOS versions, one supported by Windows 9x, the other by Windows 2000/XP/ME. It can be purchased by emailing the author in Canada (as of Sept 2004).
Can't find any info about it after 2004.
Determining the long path and short path distance and beam heading between two locations requires a number of parameters to be considered to do it accurately.
